Took me a while to get back but finally got the carpc installed. Running CF 4.2,of course...
gaps to be filled.
OBDII
Destinator, OZ map
MP3 Player
...now here's the story. Initial problems encountered so far. With the TC1000,the only prog loaded is CF and I was playing MP3 while navigating...Voice prompts are all garbled in destinator. I've got 512 mem, i'll try and update all the drivers see if this will help bec. the TC1000 appears quite slow. The unit is noisy but once connected the engine noise drowns the units fan noise.
GL701-TV/C/T. There is this TERRIBLE humming noise as soon as you turn on the unit that increases with speed. Even with the unit properly grounded and noise filters connected the noise is still there. This unit comes with an analog TV tuner that does not work even with the best antenna around. FM is weak and can't pick any AM signals. Even with professional installers doing the job, I THINK the noise is inherent with this unit.
Be warned, other than the good looks, I honestly think this combination (Lilliput TC1000, GL701-TV/C/T) is a resounding DUD.
LinkBack URL
About LinkBacks
