Results 1 to 10 of 11
Thread: 2 DVI connections from 1 DVI port
    Jul 2004
    Not for my CarPC, but a general hardware (video) question that I can't find an answer for...
    I need to connect 2 DVI displays (Dell 2405 monitor and Infocus 4805 projector) to a video card (ATI Radeon X300) with only 1 DVI port.
    Is it possible to accomplish this? If so, how? I know there are DVI switches, but they seem to be $250+ and are geared for home theatre use rather than PC use.
    Variable Bitrate nkotch's Avatar
    Dec 2005
    FL
    After some searching that's all I see to (expensive splitter boxes).... it is a digital signal so there's going to have to be some circuitry involved to keep the signal up.
    It's probably not an option but could convert to 15pin analog video connection and those splitters are cheaper.
    Nick
    '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
    2006 Chevy Equinox LS (Current Project)
    **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
    Fusion Brain Creator
    Mar 2005
    Dec 2005
    FL
    Hmm... good find. If you end up trying it let us know how it works.
    Nick
    Jul 2004
    I didn't want to mention it in the original post just so I kept it simple, but I bought one of those DVI splitters from monoprice. It doesn't work as is. Both displays (monitor and projector) won't work at the same time.
    That makes me ask the question - what application is that splitter intended for since it doesn't seem to actually "split" my DVI signal? Is the splitting ability possibly limited by my video card? In other words, do some video card's chipsets allow for attaching a DVI splitter and others don't?
    My card has a DVI output as well as a VGA output so it seems that it has 2 separate display controllers....I just don't understand how to get those 2 outputs to be DVI!
    Mar 2005
    link to "monoprice" DVI splitter?
    Jul 2004
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    In your case, what's the press to use DVI with the projector? In the environment you're in, will you see the difference, and will it matter? With the LCD, I can understand..
    I'd try seeing if you can clone the display between the DVI and VGA ports, don't bother trying to split the DVI signal. Sometimes the simplest method is best.
    Unless you want to go out and get a new video card that supports dual DVI outputs.
    Dec 2005
    FL
    I was a little skeptical of that monoprice unit because it's just a cable splitter.... as opposed to the powered splitter boxes I saw everywhere else. I'm pretty sure those will work for you, but it's just a lot of $$$. I know you split the output because that's what a lot of electronic stores do to split Hi-Def DVI tv to multiple TV's on the showroom.
    Nick
    Jul 2004
    After reading some responses here it seems that the best thing to do may be to buy a new video card that supports dual DVI outputs.
    I was hoping that I just wasn't aware of some sort of easy way to accomplish the task at hand, but it sounds like NO
    Thanks for the responses guys, and if anyone has any other ideas - by all means respond here
    I'm still wondering what application that monoprice splitter is supposed to be used for since it doesn't seem to work for the most obvious application...
  1. USB port power dies?!
    By pixelflash in forum General Hardware Discussion
    Last Post: 10-22-2007, 10:26 AM
  2. SDK commands over the serial port ????
    By tolisn in forum Road Runner
    Last Post: 12-14-2005, 01:03 PM
  3. Replies: 4
    Last Post: 07-04-2005, 05:38 AM
  4. DVI Port Pinouts
    By CoconutColin in forum LCD/Display
    Last Post: 12-13-2004, 10:40 AM
  5. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 09:48 PM
