Results 1 to 8 of 8
Thread: Car amp in a home?
    Apr 2006
    Car amp in a home?
    Does anyone know how to put a car amp onto a regular computer? The trouble I am having is basically getting power to the amp itself. Any suggestions?
    Mar 2006
    Colorado, but Canadian!
    Use a PSU with a good solid 12v rail. Usually the yellow wire. I personally would just use the computer's PSU for the remote turn on lead, and then use some seperate source for the actual power like a cheap 120vac-12vdc transformer from Radio$hack.
    Aug 2004
    that simply wont work. a radio shack power supply will give you 1 to 2 amps, which might be enough to turn on a car cd deck, and might turn your amp on, but you'll surely fry it or activate the over-current circuit with a reasonably powered amp.
    you'll need a real, professional power supply. Car stereo shops use them to power the demo boards. A decent 50 amp unit will run you a few hundred bucks. They are huge and get really hot.
    In addition, car amps are (mostly) made to drive a 4 ohm load. House speakers are usually 8 ohms. Your 200 watt car amp will only make 100 watts at 8 ohms, so it will be pretty quiet, and might not be as good an idea as you think...
    FLAC SnyperBob's Avatar
    Nov 2001
    Illinois
    well what kind of amps does a car battery put out, I think that's what he's asking.
    Obviously it's 12 volts, how much amps?
    www.mobile-effects.com
    Free file hosting, picture gallery hosting for installs, PM me.
    Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
    Mar 2005
    Quote Originally Posted by Vinister
    rampant misinformation here...
    100 watts is only ~3dB quieter than 200watts.
    a computer PSU can output ~20A on it's 12v rail. 12*20 = 240. That is more than enough to run a 200 watta amp.
    Toss a SLA battery in parallel so that the amp has somewhere to draw if the load peaks over 20A
    @SnyperBob: car batteries can generate nearly 1000A in a short-circuit condition. how much the car battery can generate is not the right way to solve this design problem.
    Low Bitrate ilyassx's Avatar
    Oct 2005
    Belgium, Denmark
    Quote Originally Posted by JoshG
    Hi,
    Use the computer PSU it's work perfectly especially if you find the old AT PSU 200W, i'm using one with Pioneer GM-D510M to power my subwoofer in garge.
    Cheers,
    The old setup http://flickr.com/photos/ilyassx
    The new setup http://my.opera.com/ilyassx/albums/show.dml?id=110701
    Jetway J7F2WE VIA C7 1.5 GHz
    512 DDRII 533
    3.5" SATA2 H.D.D 200GB
    M1-ATX
    ELM327MS OBDII
    Creative Audigy 4
    PROGRESS:[########-]90%
    Mar 2006
    A PSU should work fine, but I wouldn't use the same PSU as waht your computer runs on. I wouldn't want anything to happen and then the "regulated" PC voltage go crazy and blow up.. I would use a spare that probably everyone has.
    Feb 2006
    NWI USA
    I got a buddy who has 2 15" lanzars and some sickening amp running off A regualr car battery hooked to a trickle charger in his living room. He keeps the cahrger on all times and uses the 15's for his subs for home theater(from reciever sub outs). complete overkill. it does work however.
  1. Home speakers in the car
    By impulsenine in forum Car Audio
    Last Post: 11-23-2006, 03:57 AM
  2. PC Power Supply and Car Amp
    By GezusK in forum Car Audio
    Last Post: 05-10-2006, 01:31 AM
  3. noobie needs advice on buying a car amp
    By minghi in forum Car Audio
    Last Post: 03-30-2005, 11:00 AM
  4. car amp with default speakers?
    By 273BeLow in forum Car Audio
    Last Post: 03-30-2005, 12:53 AM
  5. car amp power supply
    By fuctup in forum Power Supplies
    Last Post: 11-03-2004, 02:52 PM
