Results 1 to 10 of 14
Thread: Is 10 Gauge enough for M2-atx?
    Constant Bitrate ironic's Avatar
    Aug 2005
    Gibraltar(UK)
    Question Is 10 Gauge enough for M2-atx?
    Hey guys.
    Is 10 gauge wire enough to power the m2-atx??
    What about ground wire?
    Thanks.
    MSI KM4M-V Mobo -- AMD Athlon XP-M 1900+ -- 512MB DDR RAM -- LinITX 7" Touchscreen -- Seagate 8.4GB HDD -- LG DVDRW -- Onboard Graphics Card -- Onboard 5.1 surround sound -- Bluetooth Dongle -- RoyalTek Saphire GPS -- M2-ATX psu
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    I'm going to assume probably.
    Ground should be at least as thick as the 12v source.
    Variable Bitrate nkotch's Avatar
    Dec 2005
    FL
    That's what I run my OPUS 150 from.
    Nick
    '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
    2006 Chevy Equinox LS (Current Project)
    **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
    Constant Bitrate Specimen's Avatar
    Jul 2005
    Los Angeles, CA
    10 is fine
    PROGRESS [==========-] 99.9% <- Are we ever really actually done with our carPCs?
    Variable Bitrate DaveB's Avatar
    Mar 2004
    I'm of the opinion that you can even run 16 gauge. If you look at the 3 wire pigtails that come with the M2-ATX, they are no heavier than 16 gauge.
    8" Lilli TS
    MB896F Mini-ITX MB
    2GHZ Dothan 533MHz FSB CPU
    1GB SDRAM DDR2 533
    Seagate 300GB SATA150 HD
    ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
    Pioneer Slot Load SLIM DVDRW
    Bluetooth V2 USB 2 Dongle
    3COM BKP Cam
    Constant Bitrate Legarcondemerde's Avatar
    Jul 2005
    The Biggest Little City
    I'm going to use 16ga. I agree with DaveB. Of course, my wire run is only going to be about a foot, and it's also kind of relative to where you are going to connect the power wires--the longer the run, the higher the resistance, and the thicker the wire should be.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    16 gauge is pushing it if you're going more then a foot or so. i would never tun that the length of the car...but then again i dont want to set my car on fire
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Jul 2005
    Los Angeles, CA
    Why even chance it, its not like it costs a ton more to get a 10 or 12 gauge wire. 16 is pushing it. You can get away with it ONLY if you are running a short distance < 1 foot and even at that its not a good idea. 16 gauge on average is only rated at around 10A, while 12 AWG is at 20A and 10 AWG is at 30A. So that’s not good to have a 10A limited wire when your M2-ATX has a 15 amp fuse blade. Your wire will melt before you even blow a fuse. Also since I know people are all about cheap wires when it comes to this kinda stuff, the insulation might be crappy and limiting your current limit even more.
    Low Bitrate ilyassx's Avatar
    Oct 2005
    Belgium, Denmark
    Quote Originally Posted by Specimen
    I agree
    The old setup http://flickr.com/photos/ilyassx
    The new setup http://my.opera.com/ilyassx/albums/show.dml?id=110701
    Jetway J7F2WE VIA C7 1.5 GHz
    512 DDRII 533
    3.5" SATA2 H.D.D 200GB
    M1-ATX
    ELM327MS OBDII
    Creative Audigy 4
    PROGRESS:[########-]90%
    Nov 2005
    and
    A good rule of thumb is to fuse smaller than your wire rating. The M2-ATX is fused at 15A. I have a separate 10A fuse a couple inches from the 'hot' 12v terminal of the battery.
    I am running wire rated at 30A and approximately 11AWG to 10AWG. (Not the whole world's wires are rated to AWG, you know..) Wire run length is about 2 metres.
    As for voltage drops over long wire lengths on 12v, there are lots of wire length/resistence calculators out there. iirc, the last time I checked - anything better than 12AWG carrying 15A at 12vDC over 6 feet or so should see a voltage drop under 5%.
  1. Replies: 22
    Last Post: 03-09-2005, 11:27 AM
  2. Mounting motherboard in WRX gauge pod housing..
    By Giuliano in forum General Hardware Discussion
    Last Post: 07-19-2004, 10:01 AM
  3. New Idea for an awesome atx shutdown
    By moahdib in forum Power Supplies
    Last Post: 07-03-2002, 12:42 PM
  4. ATX and AT motherboard
    By Beavis in forum Power Supplies
    Last Post: 05-10-2001, 03:22 PM
  5. ATX to AT conversion?
    By drew in forum General Hardware Discussion
    Last Post: 10-27-1999, 02:28 AM
