know what i just realized...you have that dqx and all you need is 2 chans. go with a usb dac. wont be that expensive and better quality then most of the soundcards.
read through the last few pages of this thread:
1/3 Octave Software EQ
we've posted a ton of info on getting great audio out from the computer, trying to bypass the alpine pxa-h700
i have a few links and some info on the usb-dacs. all of them are external and are the best way to go. i think you'll be spending about 150 or so.
oh.. and still look for the higher voltage outputs. it will mask more noise that will get introduced from the usb-dac or soundcard to the dqx
edit:
so i was bored...here is the post that i primarily wanted you to read:
but you should read through the other posts as well.... oh, and did i mention, these boards will have rca outs? so no worries about sharing a signal on that skinny little shared mini jack.
BUT before you go and buy anything, since you have a soundblaster live 5.1 card, i highly suggest loading the kxproject driver and playing with them for a couple weeks. when i had the sb live card and my 24xs installed, i was shocked at the sound quality. sometimes i liked it better then the pxa-h700 (may be because i am not that great at tuning) but it did do wonders over the regular sb drivers and you can practically rewire the card internally. and you can set up time delays and what not.
LinkBack URL
About LinkBacks
