RCA Y Adapter
If I convert the 1/8" plug from the CPU to a RCA cable, can I then use a RCA Y Adapter to connect both the Head Unit and the CPU to my Amp? I've read all the post and done a search but don't see anyone using this option. I don't have a AUX on my Head Unit, can't use the cassette adapter (because head unit is CD player) and don't want to use the FM modulator. My Amp & EQ only has input for one source. The only other idea I could think of was to build some sort of RCA switch box.
Any ideas or URL's would be of great help. Thanks
yes you can use a Y-adapter to connect the 2 sources to your amp.... Building a switching system is also very very easy. But, not necessary for your set up.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
