Results 1 to 8 of 8
Thread: Using resistors
    Mar 2002
    haiti
    Question Using resistors
    I 'm making a ir receiver for which i found the schematics in the web . i need a resistor of a value i cant find can i add other resistor up to that value and if yes is there a polarity i should respect ?
    FLAC mp3z24's Avatar
    Apr 2001
    Chicago Suburbs
    basic electronics:
    resistors in series (one after another):
    R(total) = R(1) + R(2)
    resistors in parallel (side by side, with their lead connected):
    1/R(total) = 1/R(1) + 1/R(2)
    or
    R(total) = {R(1)*R(2)} / {R(1)+R(2)}
    someone PLEASE correct me if im wrong.
    also, the equations can be continnued for more than 2 resistors, although the second eq for the parallel gets pretty hairy. just use the first one (for parallel) and a calculator!! the series one is always easy.
    oh, and the equations are switched for capacitors.
    ~mike
    Single Member of the "1000 Post and No MP3 Car" Club
    PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
    2000 Cavalier Z24 [###-------] Only 30% Done ... Still
    Jan 2001
    Adelaide, SA, Australia
    you are correct.
    resistors is parallel are strange things.
    On another note does any one know a site with the chart to tell you what coloured bands you need for a particular resistance??
    hornet
    http://www.mp3vl.tk Plans and progress on my install - (Updated 28 June 02)
    Australian mp3car Portal
    mp3car related links Check them out / Add some
    mp3car FAQ - RTFF
    [########==]80% Assembling
    -=Current Progress: Working Sproggy supply, building box.=-
    Rob
    Rob is offline
    Maximum Bitrate Rob's Avatar
    Aug 2001
    Missing In Action
    No but
    0 = Black
    1 = Brown
    2 = Red
    3 = Orange
    4 = Yellow
    5 = Green
    6 = Blue
    7 = Purple / Violet
    8 = Grey or White (can't rember which but nobody uses 8)
    9 = Grey or White (can't rember which but nobody uses 8)
    The first 2 or 3 (depends on the resistor) colour bands are the first 2 0r 3 numbers in the value and the last band is the number of zeros.
    I think an example might help
    red red yellow would be 220000 ohms or 220k ohms
    yellow purple black red would be 47000 ohms or 47k ohms
    The odd colour on it's own normaly gold or silver is the tolerance, just ignor it.
    I cann't rember which way round you read the colour bands, but one way makes sense and the other doesn't.
    I hope that make sense, rather than confussing things.
    Rob
    PS. Does any one know which is 8 & which is 9
    And you say people actually pay money for M$ Windows?
    www.mp3mini.co.uk (Does what it says on the URL) www.openclassic.co.uk (The new car, with zero rust!) www.rob-web.co.uk (My other site)
    Total re-design underway: on the whole progress is very slow as the car is taking up too much time :)
    Constant Bitrate jboy's Avatar
    Oct 2001
    MA
    8 grey
    9 white
    Apr 2001
    Chicago Suburbs
    this calculator is pretty handy if you are working near a computer.
    ~mike
    Feb 2002
    Seattle, WA
    mp3z24,
    Man, that calculator and that entire site, rocks!
    I can't get over the stuff you can do with Java.
    Wellfooled
    Workin' on an mp3 Sequoia
    May 2001
    Thessaloniki, Greece
    Solder a small pot, adjust it, then use a drop of superglue to permanetly fix it's value.
