Results 1 to 9 of 9
Thread: splitting cigarette lighter for inverter
    Mar 2001
    Post splitting cigarette lighter for inverter
    I'm going to splice into the cables for the cigarette lighter to power the inverter.
    Anyone know if I can leave the cigarette lighter socket still connected, or should I disconnect it? It'd be nice to have the socket still available, but I don't know if that'd electrically 'work'.
    Player: Celeron II 633MHz, 256MB RAM, 20GB IBM 9mm 2.5" Laptop HD (180G/2ms), onboard ethernet/sound/video/tvout, 10"11"x3" case, MPBS1 70W DC-DC PS w/auto-shutdown controller, in-dash lighted switches, 7" NTSC TFT widescreen in-dash LCD, touchscreen, rear-window brake light installed Garmin GPS35 GPS, credit card sized IR remote w/IRMan, mini-wireless keyboard/mouse (sits under seat), PowerMate black knob, MP3s and GPS Navigation (Winamp, CoPilot, SA8.0).
    Car: 1993 Nissan Maxima, Black Emerald
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    Post
    That's what I did.
    I have a plug in the trunk for the inverter (that I installed) and left the one in the dash still hooked up.
    They are both spliced from the same wire.
    Aug 2000
    Post
    Yes you can do that but...
    1.) if your the lighter is not attached to the accessory power in your car remember to install an on off switch (or you will drain your battery)
    2.) remember to put an inline power fuse on the wire that u spliced going to the inverter.
    Mar 2001
    Post
    Is the inline fuse really necessary if the inverter has its own built in fuse?
    Jan 2001
    Adelaide, SA, Australia
    Post
    never can be too cautious. Especially when electronics are concerned
    http://www.mp3vl.tk Plans and progress on my install - (Updated 28 June 02)
    Australian mp3car Portal
    mp3car related links Check them out / Add some
    mp3car FAQ - RTFF
    [########==]80% Assembling
    -=Current Progress: Working Sproggy supply, building box.=-
    Aug 2000
    Post
    YES an inline fuse is necessary...
    Ok just a bit of advice for all. If you add any devices to your car and it is not a direct replacement for a piece of factory equipment then yes you should/must add an inline fuse even if the device has a fuse attached to it... I am late for work i will talk more about this later if necessary
    Mar 2001
    Southbury, CT, USA
    Post
    The fuse for the cigarette lighter is not good enough for a real electronic system. You could easily burn out your cigarette lighter and other assorted things w/o a different fuse. A friend of mine did that to his mom's Chevy (then he got his Celica, so he kinda whistled and walked away ;-)
    Mar 2001
    Post
    What size fuse should I use? The same as the one for the circuit in the fuse box?
    Aug 2000
    Post
    the same size that is in the inverter
