Results 1 to 10 of 10
Thread: Prolific USB to Serial causing MP3 Problems
    Dec 2005
    Ontario
    I'm posting this since I haven't found a solution yet:
    MP3's play with an intermittent/occasional stutter or dropout (choppy)... I've already figured out that the cause of the problem is the Serial-to-USB adapter built into the GPS unit.
    I have a Hollux GR-213 GPS mouse receiver attached via USB to a hub... My sound card is the Creative Audigy 2 ZS PCMCIA and both devices are set up with the most up to date drivers.
    Whenever I enable the Prolific serial port driver within device manager, MP3 playback is affected. It's not terrible, however it's subtle enough to compromise the sound. If I disconnnect or disable the GPS, the playback problem goes away. It only affects sound file playback ie .MP3 and has no effect on Line IN/Mic IN.
    I'm using an IBM thinkpad A22M laptop and have numerous USB 1.0 devices connected via a USB hub including the touchscreen, Griffin PowerMate, Dlink FM Radio and of course the GPS.
    Any gurus dealt with or have a solution for this one?
    ***My bad... this was supposed to go to the General Hardware Discussion***
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Thread moved.
    Hmm. I use the Prolific Serial to USB bridge for my GPS and haven't experienced this problem. I'm using a Via M10000 with no hub on it, although I've had an unpowered hub with stuff on it and no problem.
    Want to:
    Apr 2006
    it's sounds like interrupting problem, try to use another interrupt/dma for the converter emulated com port ?
    Feb 2006
    Central FL
    Drivers
    We use these for products we sell at my company. MAKE SURE you are using the new 4.x driver. The old 2.x sucked. (don't know what happened to 3.x)
    Kayakanimal
    Maximum Bitrate pyros's Avatar
    Mar 2004
    Toronto, Canada
    Where do you find the 4.x driver? I only see the 2.x driver on their site:
    http://www.prolific.com.tw/eng/downloads.asp?ID=31
    2004 Ford Mustang Mach 1
    Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
    Install Status: DONE
    My XM FAQ
    Feb 2006
    Central FL
    Quote Originally Posted by pyros
    OK...feeling like a nice guy today. I think these should work for you. Let me know when you get them so I can remove them from my ftp site.
    Kayakanimal
    Click HERE
    Mar 2004
    Toronto, Canada
    got it.. thanks! I'll try it out when I get home
    My XM FAQ
    Dec 2005
    Ontario
    Sweet - got it!
    I'll try it tonight and post feedback...
    THX
    Feb 2006
    Central FL
    Did it work for you?
    Dec 2005
    Ontario
    Sorry for the delayed reply...
    Unfortunately I haven't got it to work... It may be something I'm doing wrong or the drivers might be incompatible with my serial to USB bridge. Whenever I try to install the version 4.x drivers, they install, the machine requests a reboot, and after the reboot, the drivers revert back to version 2.x (as confirmed in device manager).
    I've tried uninstalling the old drivers manually, I've tried a utility from Prolific to uninstall old drivers and I'm sure I tried some other techniques as well to no avail.
    The original problem is still haunting me... bad audio file playback... So I just listen to XM for now.
    If there's a way to get er working I'm all ears.
  1. Problems with Usb to IDE Adapter
    By -zip- in forum General Hardware Discussion
    Last Post: 08-22-2005, 03:40 PM
  2. USB 2.0 problems with Windows
    By kalgra in forum Input Devices
    Last Post: 06-13-2005, 03:23 PM
  3. Replies: 6
    Last Post: 01-21-2005, 02:12 PM
  4. USB HUB problems????
    By chuckctv in forum Input Devices
    Last Post: 10-08-2004, 11:38 AM
  5. Handheld + USB Hard Drive := Ultimate MP3 Player
    By PoBoy in forum General Hardware Discussion
    Last Post: 06-08-2001, 08:22 AM
