Results 1 to 7 of 7
Thread: hello--im new here--Noob question
    May 2006
    hey guys,
    so im thinking of getting one of these car pc--the pandora one...anyhow i wanted to know what needs to be done to get the music to play from the pc to the car stereo... i know theres an opitcal out and all that ....but how do you actually hook it up to play music or sound through the car speakers...im getting xenarc touchscreen and imobile software if i decide to do this project...
    so my question is...what is needed or how do i get the music to play off the pc and through the car speakers.
    Jun 2004
    Central California
    Start reading the FAQ section and you'll find an answer to your question.
    EPIA Nehemiah M10k, M1-ATX, 20GB 4200 RPM 2.5", 256MB RAM, Win XP Home, Gyration RF Keyboard & Mouse, Zoltrix Nightingale Optical 4.1 PCI Sound Card, Lilliput 619GL-70NP, XM-PCR w/ optical upgrade, Garmin GPS-25LVS, Microsoft MN-710 USB Wireless NIC
    May 2006
    Quote Originally Posted by edikp
    thx
    May 2006
    Quote Originally Posted by poohbutt
    thx
    ok i checked the forums and i appreciate your help! my more detiled question is as follows:
    i do not have a "sound" card per se like a creative blaster on this machine...it is a mini pc comparable to a mac mini....there is a line out for speakers...and wanted to know if this is suffice for the splitter which will go to the amp....because on the diagrams i sawit looks like the sound card has seperate splitters for both the front and rear speakers..
    if there is just one line out...and i use the splitter...will it compromise the sound quality for either the front or rear speakers?
    anyone with a pandora able to help?!
    Elsewhere
    I use the onboard sound of my Shuttle unit and it sounds great. It may be slightly better sound quality with the nForce2 chipset than the AOpen Pandora, if better at all.
    Unless you're a serious audiophile or sound reproduction junkie, you're probably not going to notice the difference.
    How about the Wiki?
    Mar 2006
    Colorado, but Canadian!
    No matter what, you will need an amplifier to get a good volume. The pandora I believe has the three connectors that can be used as 2 out and 1 in or a driver can switch to 3 out using the mic port. Then just take that into a 1/8" to RCA, pluig into amp, wire to speakers. Keep in mind that every 1/8" jack, carries 2 channels of sound, and that is why the 1/8" to RCA, gives you a red and white phono sound. Do that twice and you have 4 speakers like in a car, and if you have a sub, then use the fifth channel. I think the microphone when changed to output only gives mono but I'm not sure.
    EDIT: beat me to it!
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  1. Another noob question
    By Pokiarchy in forum Software & Software Development
    Last Post: 11-16-2005, 07:44 PM
  2. Dumb noob question
    By TaZMaNiaK in forum FrodoPlayer
    Last Post: 04-02-2005, 01:52 AM
  3. A nOOB question about monitors.
    By GATrooper in forum LCD/Display
    Last Post: 10-12-2003, 03:21 AM
  4. noob question
    By sugarmychurro in forum General Hardware Discussion
    Last Post: 05-19-2003, 08:34 PM
  5. Hardware question by a Noob
    By SavedSoul777 in forum General Hardware Discussion
    Last Post: 04-07-2003, 09:53 AM
