Results 1 to 9 of 9
Thread: Burning smell?
    Dec 2000
    Beaverton, OR
    Post Burning smell?
    This is sort of off-topic (I do a lot of that kinda posting though).
    I have a couple of monitors here that are emitting a strange phosphorus odor when they run. Is this normal? I've never had one do this before, and they're both rather old/****ed with.
    Aug 2000
    Post
    ok, it is producing a burning smell but, is it getting very hot or producing smoke, if not then you don't have a problem. sometimes with age and the dust and other debris settling in electric devices you may start to get a fun smell, that is hardly noticable unless you put your nose to the machine and try to smell something... Are you smelling this sent from far away or only when you put your nose by the screen. If you can only smell it from close up then don't worry about it b/c as i said many devices do that (go smell the back of your TV and you shall see).
    but anyway i would not worry yet
    Mar 2001
    Post
    Several times I've bought new monitors and they've put off a very distinct chemical burning spell.
    Once it was so severe that before we realized what was wrong, but my father and myself were puking. We returned that particular monitor. The replacement for it (and other new monitors we've gotten) had the same smell, but much weaker.
    In all cases, I kept the area well ventilated for a few days and the smell went away. I can only guess that there's some chemical coating on some of the parts put on during the manufacturing process and when you first run the computer, it takes a little while to burn it off.
    My advice: _Ventilation_ and keep it running for a few days. If it's still real bad, I wouldn't use it.
    Player: Celeron II 633MHz, 256MB RAM, 20GB IBM 9mm 2.5" Laptop HD (180G/2ms), onboard ethernet/sound/video/tvout, 10"11"x3" case, MPBS1 70W DC-DC PS w/auto-shutdown controller, in-dash lighted switches, 7" NTSC TFT widescreen in-dash LCD, touchscreen, rear-window brake light installed Garmin GPS35 GPS, credit card sized IR remote w/IRMan, mini-wireless keyboard/mouse (sits under seat), PowerMate black knob, MP3s and GPS Navigation (Winamp, CoPilot, SA8.0).
    Car: 1993 Nissan Maxima, Black Emerald
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Cool
    The insulation on the HV cable from the flyback transformer had broken down and is allowing corona formation. You can wrap the wire in HV tape to try to cure the problem, or replace the flyback (expensive). Another possibility is that the deguassing coil is stuck on. This is really bad, as it forms a short accross 120V. Perhaps the relay is stuck? If you can't fix it, just disconnect the coil as it really isn't that necessary.
    Aaron Cake
    Player: Cyrix 200, 32MB RAM, 10.2Gig Quantum HD, Onboard EtherNet/Sound/Video, Custom Lexan Case, Arise DC-DC, Win95 Kernal w/Custom Player
    Car: '86 Mazda RX-7 w/Basic Performance Upgrades
    Bj
    Bj is offline
    Aug 2000
    Perth W.A Australia
    Post
    Just be a bit wary. If they have been "****ed with" they may not have the over voltage shutdown circuit working properly. Basically this means if your HT supply is above it's normal threshold, say 28KV, it will produce dangerous amounts of xray radiation. This has been known to cause the "ozone" burning smell. Be very careful when twidling pots and the like in monitors and TV sets, you could be doing some serious damage to you.....
    But apart from that, Aaron is right, it sounds like your HT cable has broken down, or the flyback has an internal arcing problem. I don't think it would be the deguassing coil, as the load from it would blow the internal fuse after about 30mins usually anyway.
    Just be careful if you play, nasty voltages in there...
    BjBlaster! Car MP3 & Carputer!
    bjblaster.com
    "The solution to one problem is only the beginning of another"
    Aug 1999
    Yorba Linda, CA
    Post
    I had a monitor die on me at work about a month ago... I was working on some code and the image started twitching and jumping around and then it went black. I checked the VGA cable and everything was fine. About a minute later the monitor started smoking! I quickly unplugged it and tried it again and it wouldn't power on
    I guess that's what I get for getting a cheap off-brand monitor.
    Jason Johnson
    Yorba Linda, California
    http://www.m2pc.com
    MPC Phase IV - *** PENDING ***
    Dec 2000
    Beaverton, OR
    Post
    Well, the first one (generic 14" VGA) stopped doing it after a couple seconds, so I assume I just jiggled something around in there that I shouldn't have. It's been working fine otherwise. The other one I haven't tried again. I don't think the latter (a 20" Wyse) has had anything done to it. I took a look inside and everything looks like it's where it should be (rather, nothing looks missing or obviously broken), but if it keeps up the smell I may just junk it.
    Dec 2000
    Beaverton, OR
    Post
    I should note that it's not exactly a burning smell, but like I said, kinda phosphorus. Like fireworks, but not as strong.
    Aug 1999
    Yorba Linda, CA
    Post
    As Aaron stated a corona may be forming due to the deterioration of or missing insulation on the HV lead. Try turning off the lights in the room with the monitor on and see if you see any purplish or bluish light inside the monitor through the vents.
    What you are most likely smelling is ozone given off when HV ionizes the air around the part that's not insulated. Also, there could be arcing inside the case from some of the HV components to the chassis.
    ... or another possiblity is the monitors are just very dirty inside and are making a smell similar to when a gas heater is fired up after not being used for a long time. You might try shooting some "air in a can" inside it to blow out some of the dust. It would be a good idea to do this with the monitor off, too.
    ...just some ideas.
    --Jason
    Jason Johnson
    http://www.m2pc.com
