Results 1 to 5 of 5
Thread: Slimline dvd to... usb?
    Feb 2006
    Hi all,
    I purchased a Pioneer Slot Load DVR-K05 (slimline laptop dvdrom) with the intent of mounting it in my dash and connecting it to my pc which is basically under my drivers seat. (3' away or so).
    I have seen (and purchased) the slimline -> IDE adapter that allows me to put it on my ide chain, however finding a 3' ide cable + power is not a good or even viable answer. Along those lines I also saw and purchased an IDE -> USB adapter, however this is also a large adapter making the slimline dvdr not so slimline. Oh, and it doesn't work when I try to connect it that way (too many conversions?).
    Does anyone have any hardware suggestions for what I am trying to do? Preferably, I'd love to use the existing dvdr that I already spent $100 on, but if that isn't possible, I can accept that.
    Thanks as always, you all rule!
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    did you connect the ide>usb adapter and also give it power? it doesn't carry its own power through the adapter so you'll have to get the 5v from your psu
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Sep 2005
    scotland
    http://www.customcarcomputers.co.uk/...3ee0bba73747b2
    something like that might suit you need better
    Feb 2006
    Quote Originally Posted by turner brown
    !@#!@$!@$!@# that's perfect!!
    Once again, problem solved via these forums. You rule
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Here's another. I just got this one and am using it via firewire. No extra power wire needed. It works with USB as well but you must give it 5V separate.
    http://www.logicsupply.com/product_i...roducts_id/422
    ~Jimmy
  1. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 11:49 AM
  2. Slow Boot With USB DVD
    By thenick100 in forum General MP3Car Discussion
    Last Post: 01-25-2006, 11:25 AM
  3. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 11:44 AM
  4. Replies: 18
    Last Post: 05-07-2005, 01:02 PM
  5. Dumb USB DVD question
    By Sir Lancerlot in forum Newbie
    Last Post: 01-31-2005, 01:59 PM
