Results 1 to 6 of 6
Thread: lcd problem
    Nov 2000
    Cornwall, England
    Post lcd problem
    help my LCD was working fine untill I removed the cable to tidy up the case wiring, then all I could get was block characters earlier today and now nothing at all. Is it possible to blow a chip on these units easily? is there a test I can do with a multi meter any suggestions or ideas would be welcomed. I've checked the wiring and it seems to be ok.
    Edie209
    Edie209
    http://www.ridgeway.plymouth.sch.uk/majikfish/majikfish.htm
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    Post
    More than likely something came unsoldered to two wires touched. I was moving stuff around and has to resolder a wire that I yanked out of place.
    Mar 2001
    West Yorkshire, United Kingdom
    Post
    right if you dont get any blocks it means either your earth or your +5v aint working. Or of course its a dead board, take the board out and use a make shift 5v sorce on the 5v pin then again make make shift earth, test with them on to see if you get it to turn on.
    If not its ****ed, if it turns on, try the pins.
    Could be your parallel port but more likely lose wires soldered onto the back of the pcb.
    Info is also on www.winwood.net/~oacar/faq/
    Under the output - lcd section
    Jose
    John McLear - [email protected]
    http://www.205oc.co.uk
    UK Mp3car slapnut
    #mp3car - Efnet
    Carplayer and Mediaengine *****
    spank gemma.co.uk for holding my motherboard for so long. still no board, wood work nearly done :|
    [-----------(90%)----] Completed :)
    pics at: http://www.zcentric.com/~mitcht/gall...me=Convertable
    Nov 2000
    Cornwall, England
    Post
    Thanks for the reply guys I wiil check that out tonight.
    Edie209
    Nov 2000
    Cornwall, England
    Post
    Well didn't get round to it last night went to see Fun Lovin' Criminals instead. Will try tonight.
    Edie209
    Nov 2000
    Cornwall, England
    Unhappy
    Well I've checked it out with a meter and the power is getting to the LCD,and all the soldering is good, so unless antone has any other ideas looks like i'm ordering another from EIO. Guess thats a lesson for us all BE CAREFULwhen moving things around.
    Edie209
    Edie209
