Results 1 to 5 of 5
Thread: No keyboard boot up questions.
    Low Bitrate vwgtipowr's Avatar
    Jan 2006
    Bedford, NH
    Question No keyboard boot up questions.
    I have a P3 500mhz compact desktop PC that I am using as a car PC.
    One of the problems I have encountered so far, is that I get a mother board error, and the PC will not boot without a keyboard plugged into the PS2 port.
    Does anyone know a way around this?
    When i eventually install this into my car, I don't want to have a keyboard plugged into the trunk, just so I can boot.
    TIA
    Any help or suggestions would be great.
    Car-PC progress meter (researching and collecting hardware)
    Constant Bitrate randomjohn's Avatar
    Sep 2005
    CT
    Quote Originally Posted by vwgtipowr
    TIA
    It's a fairly obvious setting in the BIOS. Hold down <DEL> or whatever it is to get into your BIOS on boot and look around. It's usually very conspicuous - there will be a choice from something like "Halt on Error - All but Keyboard" or something like that
    GA-K8VM800M, Sempron 64 2800+, 512mb DDR400, D-Link USB BT, Linksys .11g NIC, 250gb IDE, BU-353, SIR-ALP1 w/ MJS, DSATX 220w, DWW-700H
    Worklog: http://www.mp3car.com/vbulletin/worklogs/65059-03-jetta-if-i-can-any-idiot-can.html
    Now with pictures!
    Mar 2002
    It's kind of hit-or-miss with having the BIOS setting that randomjohn mentioned. If you don't have the option, just take apart a keyboard and just plug the circuit board into the PC (typically only a few square inches). Alternatively, you could pick up one of those older numeric keypads that hookup using PS/2.
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    Or just do as it tells you...press F1 to continue
    Sorry, had to go there
    2005 Ford Focus ST
    Jan 2006
    Bedford, NH
    Quote Originally Posted by randomjohn
    That worked perfectly, Thanks!!!
    Didn't realize that bios setting was in there.
  1. Bunch of questions .. New around here.
    By Timm3h in forum Newbie
    Last Post: 06-22-2005, 01:28 AM
  2. Replies: 6
    Last Post: 05-25-2005, 11:53 AM
  3. Laptop keyboard not working
    By Embassy in forum General Hardware Discussion
    Last Post: 10-11-2004, 12:23 PM
  4. Disabling BIOS keyboard error?
    By Squeezer in forum General Hardware Discussion
    Last Post: 02-02-2001, 08:29 AM
  5. Some questions (ok qutie alot of mumbling too)
    By TimW in forum General Hardware Discussion
    Last Post: 03-12-2000, 04:33 PM
