Results 1 to 3 of 3
Thread: questions about running +5v from psu in trunk to dash
    Oct 2004
    South Carolina
    I'm going to run a +5v line from the carpc's psu that's in the trunk to the dash to power a usb hub, and a slim slot loader dvd drive.
    I have a couple of questions.
    Should i fuse this line?
    do i need to run a ground from the psu to the dash also, or can i just ground it to chassis?
    is there anything else I need to know?
    Thanks for the help!
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    You want to run a ground because I don't think the chassis is common ground with the 5v rail, I could be wrong with a DC-DC PSU.
    I guess you don't -need- a fuse, but it could save your PSU if something happened to the wire.
    Dec 2003
    Germany
    Quote Originally Posted by Jahntassa
    In my current inverter setup the cahssis is common ground even to the PSU of the CarPC!
    Lilliput 7" TS TFT, ASRock K7VM2, Duron 1,3 GHz, 512 MB DDR RAM, 30 GB Seagate HDD @ 5.400 rpm, WLAN w/ 500mW booster, Toshiba Slimline DVD-ROM Drive, D-Link USB Radio
    Download the German Voicepack 1.0 for FreeDrive now!
  1. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 01:07 AM
  2. Cheap 5V 13A psu
    By dsoares in forum Power Supplies
    Last Post: 10-09-2002, 07:05 AM
  3. Basic Laptop PSU questions
    By Duphus in forum Power Supplies
    Last Post: 05-31-2002, 12:01 AM
  4. PSU 12V issue
    By Shades in forum Power Supplies
    Last Post: 05-23-2002, 02:59 AM
  5. Astec PSU questions
    By Machs_FueL in forum General Hardware Discussion
    Last Post: 07-26-2000, 10:52 PM
