Results 1 to 3 of 3
Thread: AudioVox FM-modulator
    Mar 2001
    Cincinnati, Ohio
    Question AudioVox FM-modulator
    I bought an AudioVox FM modulator for my mp3 computer. When I hooked it up, I had to turn up the stereo half way to even hear anything.
    I called the place I bought it from, they told me I need to boost the signal going from the sound-card to the FM-modulator.
    Then I looked at the documentation, and they said to use only "Line Level" signals as anything else will cause static and stuff.
    I can't take it back, as my grandpa cut the end of the Ground-cable when I was installing it! Any tips on getting it to work?
    I can get a 59$ amp from radio-shack that I can power off my Inverter.
    Check out my Mp3 car page at
    Clarion 200watt head unit w/ Aux in.
    Kicker 800watt 4 channel amp
    In a 96 Grand Prix SE.
    Jun 2000
    Grand Rapids, MI
    Try putting a line driver between the computer and the FM modulator.
    Oct 1999
    Oakville, Ontario, Canada
    I had that exact modulator.
    I didn't have that problem though, and I used
    it with
    Sound Blaster 32 and Sound Blaster 16.
    Sounds like there could be something wrong with it.
    Some (older) soundcards have a jumper to enable onboard amplification, you could try that.
    The output of a soundcard is more then line level, but not that much more.
    It should be working.
    Double check your installation.
    [This message has been edited by Mantis (edited 03-27-2001).]
