Results 1 to 2 of 2
Thread: Static Noise
    Low Bitrate SuprchargdMazda's Avatar
    Mar 2006
    Static Noise
    I'm in the middle of my install. I've got the monitor glued/screwed in the dash, the PC is still in the basement. I'm going to be running a HUless setup. I wasn't sure if the rear speakers in the car were run off the amp or the headunit I had in the car so I hooked up a stereo to the amp with an rca splitter and while it turns out that fronts and rears are both powered by the amp as I wanted, the new Cadence components I put in the front are giving off a bad static noise. Is this just because the stereo isn't a clean signal or do I now have a ground loop problem? The pc isn't even in the car yet so I don't know how this happened. Theres no new wires run through the car except for the VGA and USB extension cables going from the dash area to the trunk. I don't think they are causing the problem but i dunno maybe??
    Mar 2006
    One other question, how are my amps going to turn on? Does the PC send them a signal through the audio card or what? I never searched about that so I dont know
  1. Alternator Whine Only With Carputer
    By tbird2340 in forum Car Audio
    Last Post: 06-29-2007, 03:36 AM
  2. Terrible static noise on SP13000 (internal audio)
    By BlackStealth in forum Newbie
    Last Post: 05-15-2006, 02:44 PM
  3. Another Static and Hard Drive Noise Problem
    By dpom in forum General Hardware Discussion
    Last Post: 11-28-2005, 10:07 PM
  4. Troubleshooting: NOISE
    By RedGTiVR6 in forum Car Audio FAQ
    Last Post: 03-26-2005, 11:31 AM
  5. Replies: 2
    Last Post: 03-21-2005, 07:46 AM
