Results 1 to 10 of 15
Thread: How do I install my OS?
    May 2006
    Calgary, Alberta
    Well I ordered the computer without a CD ROM drive of any kind, is there a way to temporarily hook up a desktop CD ROM drive? Or do I need to find an external drive from someone? Is the USB Controller going to be installed prior to the OS being installed?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Mar 2006
    San Diego, CA
    What kind of system? The best (easiest) way to install Windows would be from an internal cd or dvd drive. I'm sure you could do it through USB, but you would need to get the USB drive recognized in the BIOS. Give us some info on what kind of connectors are on the system, then we can give you better advice. You may also want to check Microsoft's knowledgebase for info on installing Windows from USB or network...
    ~Puff
    View my worklog... I dare you... http://www.mp3car.com/vbulletin/worklogs/77267-2003-audi-a4-worklog-puffs-ride.html
    Carputer Progress [||------------------] 10%
    Mar 2006
    Colorado, but Canadian!
    Most boards since 2002 have a boot option of USB-HD, USB-floppy, and USB-CDROM. I installed on a via board with an external USB DVD burner, works fine. Only thing is IDE is 33Mb/s where the BIOS's USB speed is very very slow. I think less than 11Mb/s.
    We need more info!
    Constant Bitrate BassBinDevil's Avatar
    Nov 2004
    Vancouver Island, B.C.
    The mobo ought to have two IDE headers. Connect an IDE CDROM to the secondary IDE header and set the BIOS to boot from it. There's no easier way to install.
    Or temporarily connect the drive to another PC, format the drive so it's bootable, and copy the install directory onto that drive. Boot to DOS on the new 'puter and run the install from the hard drive.
    May 2006
    Calgary, Alberta
    Sorry, it's the prebuilt Ampie they sell here. With the m10000 motheroard and all the regular stuff.
    So I need a drive? I'll see if I can buy one, use it, and return it the next day.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Mar 2006
    The m10000 has 2 IDE headers, so you could just get a cheapo internal CD drive for like $25-$30 at a store. Always good to have a spare drive.
    May 2006
    Calgary, Alberta
    Has to be a laptop drive right?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Mar 2006
    No. The M10000 has regular 50pin IDE connectors. The Ampie case must have a 44pin converter.
    May 2006
    Calgary, Alberta
    Would the 90 watt PSU support a regular CD ROM drive for OS install?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Mar 2006
    Yup. A M10000 uses minimal power, and then the screen and that's about it. USB and stuff are not too power hungry. You will have ample room.
  1. VW Golf IV - Mac Mini install
    By Fuse314 in forum Worklogs
    Last Post: 02-24-2008, 05:25 PM
  2. Difficulty installing OS
    By sethdorlan in forum General Hardware Discussion
    Last Post: 02-15-2006, 10:35 PM
  3. xp install to laptop hdd problem
    By thecrow in forum Newbie
    Last Post: 06-15-2005, 04:37 PM
  4. Please help install a Front End
    By Zebelkhan in forum Newbie
    Last Post: 01-31-2005, 06:40 PM
  5. my opinion as Linux as an OS for carputing
    By churnopol in forum Software & Software Development
    Last Post: 05-05-2003, 01:56 AM
