All I can suggest is to check your bios settings, make sure your not getting hung up trying to detect an agp card. I had a similar problem when I was trying to run a cyrix CPU with no heatsink, it would overheat just doing the memory check and freeze. Make sure your processor is being cooled. I had a similar problem also when one of my memory chips was not seated all the way down. Just some things to check, hopefully it will be of help.
Walter Farmer
LinkBack URL
About LinkBacks
