Results 1 to 4 of 4
Thread: OMG Svideo to comp WTF
    Raw Wave lostreception's Avatar
    NY
    I have the Biostar M7NCG-400 with an integrated nvidia geforce 4 it had one head vga the other a jumper on the board that you can hook up to an svideo cable (sold sepratley)
    i can't get svideo down to a comp signal for the life of me i have a svideo to comp adapter from startech.com and i actually purchased 2 neithter work!
    i get a fuzzy greyish white display and nothing elsei can play with the contrast etc and can make a few things out but it just wont work
    now you may ask why does he want to turn svideo into comp well the psone screen im using only takes comp and from what ive heard the vga mod doesnt work on them for nvidia card but composite out should work the output on the motherboard list 4 pins 2 grounds and and 2 are y and c (see attachment)
    what can i do here im going nuts and have tried just about everything cable wise and software wise now its time to make my own cable (i guess???)
    can i modify the psone to accept svideo? arrrrrrrrggghh
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    Oct 2004
    NY
    I would try to test it on a screen that accepts svideo to confirm the motherboard is putting out... then look past that... at this point you can't know if it'sd the conversion or the output...
    don't tell me this is for your main indash screen??
    NY
    Quote Originally Posted by turbocad6
    no this is only for rearview foward cams
    but the output does output svideo
    computer carpc >ati card in my desk comp svideo in > thru the computer >y composite splitter> psone screen
    OUCH
    not very efficient but it does work
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
    Mar 2006
    Colorado, but Canadian!
    Sounds like the chrominance pin of the svideo jack on your mobo or your screen is messed up. Could be loose and therefore causing the fuzzyness because it is too close/touching the other signals.
    Can you replace the jack on the mobo or the screen?
    Can you test the mobo on a diffrent screen? If it works, then its the screens jack. At least test the PSOne screen inside on a real tv to see if it works...
    1.9in x 2.9in -- 47mm x 73mm
  1. FS: Mini AGP card - TV out (Comp + SVideo) ex. for LV671
    By turner brown in forum Classified Archive
    Last Post: 02-14-2006, 07:38 PM
  2. Comp Apps Class
    By blasterguy128 in forum Off Topic
    Last Post: 05-27-2005, 01:28 AM
  3. Replies: 28
    Last Post: 04-06-2005, 04:51 AM
  4. comp wont even Work..pSu
    By samc in forum Power Supplies
    Last Post: 04-27-2003, 11:56 PM
  5. svideo LCD, video card svideo out?
    By l0ud in forum LCD/Display
    Last Post: 09-28-2001, 01:24 AM
