Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Celeron P4 2.0
    Newbie 3D Warrior's Avatar
    May 2006
    Welland, ON
    Celeron P4 2.0
    Celeron P4 2.0 running on the full size board... edit... M-ATX board my bad...
    Should i worry about heat issues if i put that in the car?
    Really want to stick it into the trunk...
    Sugestions?
    Can there be too many fans? don't really care about the fan noise...
    May 2006
    Welland, ON
    bump
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Try reading the FAQs or just use a heatsink (HS) and fan.
    TruckinMP3
    Read the FAQ!
    Elsewhere
    Is it a Celeron or a P4? It can't be both....
    How about the Wiki?
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Quote Originally Posted by 3D Warrior
    yes, each one will draw on your limited supply of power and diminish the power available to your actual computing components.
    Elsewhere
    Quote Originally Posted by tj!2k4
    I disagree.
    He could use the decorative ones that Geishas use to hide their faces...
    How about the Wiki?
    May 2006
    Welland, ON
    so what's the magic #?
    @DarquePervert yeah it's a Celeron not a p4
    Jun 2006
    That depends on what kind of power supply you're using. Is it a Celeron or a Celeron-M?
    May 2006
    Welland, ON
    Quote Originally Posted by mach5
    where do i look to find out if it's M or not... in system properties it just says Celeron(R) cpu 2.00 GHz
    as for powers supply i don't have one yet... the MB manual says to use a 300watt but i don't see any of them in store here...
    i got HDD (might have 2) and DVD player in there pci sound card, pci wifi
    and wanted to run neons in the car using serial port... still up in the air...
    Jun 2006
    Well, you're going to be hard pressed to get any of the auto power supplies to run a mATX motherboard IF combined with standard-size hard drives, optical cards, and PCI components.
    With that much hardware, you want at least a 200w mATX power supply, and a GOOD power inverter to match (400w+ continuous load or higher).
    If you use laptop components, like 2.5" hard drives, slimline optical drives, etc, you could be safe with a 150w power supply and a 300w inverter.
    Download a program called CPU-Z. Just google search for it. It'll tell you everything about your processor you would ever not want to know.
  1. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 03:56 PM
  2. P4 2.93Ghz or Celeron 500Mhz
    By Richiescorner in forum Newbie
    Last Post: 01-10-2006, 02:01 PM
  3. FT: p4 1.7ghz, Celeron 2.0 ghz, WD 60 gig HD, Need Mini itx
    By CavityCr33p in forum Classified Archive
    Last Post: 11-25-2005, 04:17 PM
  4. Celeron 2.0ghz vs. P4 1.5ghz
    By Nicorolla in forum General Hardware Discussion
    Last Post: 01-06-2005, 07:31 PM
  5. Replies: 8
    Last Post: 05-21-2004, 03:47 AM
