Results 1 to 6 of 6
Thread: Adding USB ports to Via mobo's
    Sep 2005
    So does anyone know where i can get the connectors to add in additional USB 2 ports onto my SP13000??? I don't even know where to start looking for something like this. I need to either add in USB ports onto the mobo or to get a powered USB hub and run a switch to it to turn it on and off.
    TIA
    -Mike
    Constant Bitrate Eternalodyssey's Avatar
    Oct 2005
    St. Louis, MO
    Talking
    Quote Originally Posted by Slightly_Stoopi
    TIA
    -Mike
    Try heading over to www.frontx.com they have a great selection of USB ports and ways to put USB into just about any application. Their prices are very reasonable too in my opinion. You could also try www.pricewatch.com they have just about anything computer related with really good prices. I have used both a couple times now and both sites give good results.
    Check out the updates. Project 2003 Dakota worklog: http://www.mp3car.com/vbulletin/worklogs/85490-project-2003-dodge-dakota.html
    IS JACK BAUER GONNA HAVE TO SMACK A *****?
    Mar 2006
    Colorado, but Canadian!
    looks pretty good. Looks small enough to even fit in an Ampie case too.
    1.9in x 2.9in -- 47mm x 73mm
    Newbie hunterius's Avatar
    May 2006
    Slovakia
    TIA
    -Mike
    I use extension cables from desktop PC ( I had e few from old moterboard). Ussualy they are installed in 1 PCI slot hole and for one slot providing 2 USB ports . I used 3 extensions for 6 additional USB ports:
    "We cannot solve our problems with the same thinking we used when we created them."
    AE
    Mar 2006
    just realized that my post was cut off in the beginning rendering it useless.
    Here is the link that I refer to in #3: http://www.mini-box.com/s.nl/sc.8/ca...it.A/id.260/.f
    May 2006
    Slovakia
    Quote Originally Posted by 2k1Toaster
    Am I wrong if I say that it has male connector? I can see one pin.
    MB needs different connector for USB pins - female . Anyway - you need cable or a lot of space above motherboard.
    Looks like this
    AE
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. DSATX 220 review? will it shut down USB ports?
    By chewEboy in forum Power Supplies
    Last Post: 06-04-2006, 07:56 AM
  3. USB hub does not always initialize on boot
    By d_sellers1 in forum General Hardware Discussion
    Last Post: 05-29-2006, 04:41 AM
  4. fried USB ports
    By alti in forum General Hardware Discussion
    Last Post: 07-10-2005, 12:27 AM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
