Results 1 to 5 of 5
Thread: Courtesy Forum Check Before Placing Order
    Jun 2006
    Lafayette, LA
    I've been scouring the forums for months getting ideas on the best route to go for my carputer. I intend to use this system for GPS navigation and music/video. I could almost get away with a Pioneer AVIC-N2, but where's the fun in that? Besides, from what I've heard, I'm better off with the AVIC-N1 anyway. But what about the AVIC-Z1? I digress...
    My shopping cart at mp3car.com is packed full of, what I believe, to be the necessary parts of a good carputer. They are: Lilliput 8" LCD, M2-ATX Power Supply, Panasonic DVD/CD Slot Load Drive, BU-303 GPS Puck, and ElmScan 5. I haven't spec'd out the actual PC yet, but that's not a significant task, so I won't bother asking about it here.
    Are there any obvious flaws to my hardware? Is the BU-303 a good GPS or should I look elsewhere? Is the ElmScan 5 a good OBD-II scanner or is there a better choice? Does the Lilliput 8" fit in a Ford pickup DIN (I assume double DIN) opening? What mounting kit/brand should I use to finish off the install? I'll probably end up buying an apt model of Ford radio from the junkyard to use as a "frame" for my carputer. I intend to make it fit in the supplied opening.
    Thanks for any suggestions and hints!
    Constant Bitrate icecore's Avatar
    Aug 2005
    Estero, FL
    As for the GPS, look on ebay, holux usb gps run for about $40something and work great.
    If it is a double din, an 8" won't fit. Look in the lcd section, there are stickies with the exact measurements of the 8" lilli. I wanted to go 8" first, but found out it doesn't fit in a double din.
    The mp3car.com store has ultrafast shipping, and great costumer support...some stuff is just a little pricy..keep that in mind.
    Asus MicroATX with GeFore 6100, Mobile Sempron 3300+, 1Gig Ram, 320GB 3.5" 7200UPM HDD, M2-ATX, Gain/Xenarc 7"
    Fast IS my copilot
    Variable Bitrate Osiris's Avatar
    Atlanta (kennesaw) GA
    I dont have any personal expereince with the BU-303 but it is used by many people on mp3car so just run a search on it and read what you come up with. Same with the other stuff. About the 8" screen fitting in a double din sized dash location, unless its some odd type of dash I doubt the 8" will fit. DIN spec is 7" across if i remember correctly. Once again I advise to search here and Google. Not tring to be an @ss by telling you to search but it sounds like you have a good mental start on what you want and unlike typical stereo install, problems become alot more individual specific with a CarPC.
    Good luck.
    Osiris Networx
    --Tuning is all about price vs performance. You've got to find your own medium.--
    Jun 2006
    Lafayette, LA
    Good responses. Very much what I was looking for. Both responses only addressed the GPS and DIN issue. Anyone else have input on the other issues? Does anyone hook to OBD-II? What about USB FM Tuner?
    As far as using seach... I did. I have been using forums long enough to not fall into the "search before asking n00b" trap. I tried several searches in addition to just reading. I never found a clear-cut answer for DIN sizing. Most people are using a 7" wide aspect LCD which should be damn near as wide as a 4:3 aspect 8". I know the 7" 16:9 fits in a double DIN, hence the assumption the 8" 4:3 would. Obviously not.
    I searched for "ElmScan" and got nothing relevant except this thread and this thread. Most of the threads deal with OBD software, application, and protocol issues... not much on hardware.
    I searched for "FM Tuner" and the most relevant was this thread, but it seems a little lacking in detail and reviews. Does it work or not?
    Now the search for "BU 303 GPS" was pretty slim. For the most part, one thread, which is a thread just like this one asking about components.
    I am doing the searching, and reading, I just need better search criteria I guess.
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Sometimes site searches using Google yield better results as well as more flexibility in the use of search terminology.
  1. Song sort order problems, suddenly
    By 01black_ac in forum Road Runner
    Last Post: 05-21-2006, 04:56 PM
  2. Monsoon system in VW Jetta. HELP!!
    By SteveT178 in forum Car Audio
    Last Post: 01-14-2006, 12:54 PM
  3. Forum Etiquette
    By Enforcer in forum Newbie
    Last Post: 01-09-2006, 06:58 PM
  4. Gauging interest before placing order.
    By kenop in forum Classified Archive
    Last Post: 01-27-2005, 09:11 PM
  5. ARBY, Please check the forum on your page
    By Rireal in forum Off Topic
    Last Post: 06-21-2002, 08:09 PM
