Results 1 to 5 of 5
Thread: Are shuttle PCs good choices for a car?
    Jun 2006
    I have been looking at building a pc from scratch using a mini case and laptop parts, but then I found you could get prebuilt shuttles like this http://cgi.ebay.com/Shuttle-PC-Compu...QQcmdZViewItem for reasonably cheap. Are these good in cars assuming I wire the Opus up correctly to them? Also I see trunk mounts, how is the heat issue?
    Oct 2004
    NY
    p4's suck in a car.... an opus will be overworked trying to power that.... & it'll spew a lot of heat because of the wastefull way a p4 does it's thing...
    the shuttle form factor is good, but look for one powered by a pentium m processor... it'll cost more but be much better suited for the job....
    Elsewhere
    First off, the Opus 150w is going to have a hrd time powering that, a the P42.8 draws quite a bit of power.
    Here's a thread that will give you a better explanation about DC-DC power supplies: FAQ: Will <insert PSU model> Power Supply work with my system?
    I use a modified Shuttle SN41G2 for my setup. I only have overheating issues if my truck is parked on a hot day and the A/C isn't on.
    How about the Wiki?
    Jun 2006
    Thanks, I didnt even think about the P4 power requirements, but a M deffinately makes more sense.
    Feb 2004
    North Aurora, IL
    Quote Originally Posted by DarquePervert
    have u done anythin to help solve the heat problem?
    i have a shuttle sk41G and just recently it shuts off after a few minutes after being on (abrubtly) and i presume its a heat issue since it started roughly around the time the weather warmed up.
    I wish i knew how to do fiberglass work...
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 09:12 PM
  2. Good in house / No good in the car
    By hpric in forum Newbie
    Last Post: 03-08-2006, 08:51 PM
  3. Is this a good car pc system/ good buy?
    By lul77 in forum General MP3Car Discussion
    Last Post: 05-24-2005, 08:06 AM
  4. Would this motherboard make a good Car PC?
    By pigseye in forum General Hardware Discussion
    Last Post: 12-27-2001, 06:33 PM
  5. Is this a good computer for a car mp3 system ?
    By mprover in forum General Hardware Discussion
    Last Post: 08-10-1999, 06:37 PM
