Results 1 to 9 of 9
Thread: I need a low current relay, where to get one?
    Maximum Bitrate XxAndyxX's Avatar
    Dec 2003
    Edmond, Oklahoma
    Since the serial port only puts out like 8 mA, I need a relay that will latch using low current like that. The only relay that I found that seems like it will work is this: http://news.thomasnet.com/fullstory/479655
    That relay only requires 5 mA to latch, which is perfect BUT there's a big problem.... No one carries them. I've called many distributors, but the product just isn't being sold. ETA (the manufacturer) has a $1,000 minimum order, so that's out of the question.
    Does anyone know where I can get a low current relay that will work off of less than 8 mA?
    Dec 2003
    Edmond, Oklahoma
    Come on, I know I'm not the first one to do something like this.
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by XxAndyxX
    True, but you seem to be going about it in a strange way. Rather than get a low current relay I would use a transistor to amplify the current.
    I usually use an bipolar NPN open collector arrangement for switching loads.
    Newbie hunterius's Avatar
    May 2006
    Slovakia
    May I ask you what do you need to switch-on?
    "We cannot solve our problems with the same thinking we used when we created them."
    AE
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    As Rob said, use a transistor. If you need a relay, use a transistor to drive the relay coil.
    Dec 2003
    Edmond, Oklahoma
    I'm trying to control my amps. I figured a low current relay would be easiest, but I guess I'm going to resort to a transistor, or maybe try running the DTR and RTS together to get more current.
    May 2006
    Slovakia
    well, as I looked at my amps specs ( audison and sony) no one needs more then 5mA for remote . I think that you dont need any relay. Just one mosfet transistor and you can use it for 10 amps
    rob: I think that mosfet is in this case better than bipolar , don't you think ?
    AE
    Dec 2003
    Edmond, Oklahoma
    I would like a relay for protection. Using a relay would isolate the circuits, therefor protecting my motherboard and other computer components.
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by hunterius
    Not a big difference at this current. If you are using an n-channel fet as a high side driver, afaik you need to generate a gate voltage higher than the voltage you are switching to saturate the gate. This can involve charge pumps, etc... P-channel are easier to use, but seem to be harder to find.
    I've always found bipolar easier to use, and harder to destroy.
    But as I said, it doesn't make a lot of difference for low current.
  1. Remotely startup laptop...? (wake on lan)??
    By Pro in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 01-13-2006, 07:57 AM
  2. Current through a relay between two batteries
    By RFMan in forum Power Supplies
    Last Post: 07-25-2005, 03:13 PM
  3. Power to turn on an automobile relay
    By MatrixPC in forum Power Supplies
    Last Post: 01-30-2005, 08:55 PM
  4. Replies: 52
    Last Post: 09-28-2004, 06:38 PM
  5. 12V relay + diode question
    By cybermob2 in forum Power Supplies
    Last Post: 05-18-2004, 01:11 PM
