Results 1 to 5 of 5
Thread: help with slimline cd
    Mar 2004
    ive got a few slimline cdroms and got an adapter form another member here but it seems not not be working
    the cd rom drives will spool up and spin the cd but none of the computers that i put it on will work it --- i dont know if windows will or should see it -- it dosent
    the adapter i have is the same one that most everyone has -- floppy power connector 4 pins (for the standard audio out) and another set of 4 pins encased in a white connector (digital audio??) the other side is the (jae??) connector to connect to the cd rom drive
    now the drives i have are from 97/98 one is a toshiba the other is a torsien brand 12x and 14.5x -- maby these are to old i dont know
    any thoughts from anyone --- if they are at there limit then ill shoot over to the selling forum and post a want to by
    thanks
    chad
    Mar 2004
    35 looks and no responce??? any one have a clue!!!
    thanks
    chad
    _
    Mar 2004
    Little Elm, Texas
    do you have anything else you can plug the drive into directly and test it?
    into a laptop with a removable slim drive with the same types of connections?
    are you absolutely sure that the drives are good?
    I had an instance where no matter what I did, the drive just wouldn't work, it would spin up, light would come on, it would read, then it would die, I tried EVERYTHING...and nothing worked...except for getting a new drive.
    If you think the drive is good, I might be able to dig up my old thread. It might help you with some troubleshooting ideas.
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Jan Bennett
    Newbie hunterius's Avatar
    May 2006
    Slovakia
    I had some issues with my slim-drive and adapter too
    some suggestions:
    - try to rotate cable connected to adapter
    - try to use old ATA33 cable
    - in bios use choice "auto" for drive detection
    (my bios don't want to find DVD-drive anyway but windows does and working fine
    "We cannot solve our problems with the same thinking we used when we created them."
    AE
  1. Cheap Slimline CD DVD CDRW drives
    By patdpolishpower in forum General Hardware Discussion
    Last Post: 06-22-2005, 02:32 PM
  2. Help!
    By WRX2001 in forum PhoneControl
    Last Post: 01-25-2005, 04:50 PM
  3. WTB: Slimline CD Adapter
    By kuwupt in forum Classified Archive
    Last Post: 10-12-2004, 02:25 PM
  4. Slimline cd rom pin out?
    By Leviathan in forum General Hardware Discussion
    Last Post: 06-07-2004, 11:42 AM
  5. FS: Slimline CD & DVD, 512MB CF Card
    By StratusPh34r in forum Classified Archive
    Last Post: 01-31-2004, 09:31 PM
