Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Via Epia Mii10000 USB
  1. #11
    Maximum Bitrate buurin's Avatar
    Sep 2005
    Seattle, WA
    The PCMCIA USB is a really good idea. Thanks.
    I haven't tried to delete the USB stuff from device manager yet. Honestly I have little hope that will work but I will give it a shot before I buy anything.
    Thanks again everyone.
    B Smoov
    Project Status: 90% Complete
    Next Step: TIVO for Radio
    Ampie Case :: MII10000 Mobo :: M1-ATX PSU :: 512MB RAM :: 2.5" HD, 60GB, 5400rpm, 16MB Buffer :: DWW-700H :: Centrafuse
  2. #12
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by buurin
    Where in the world can I get USB ports to connect to the onboard jumper pins usually used to connect to front panel usb ports?
    That seems like my only option.
    http://meritline.stores.yahoo.net/dualusbrecto.html
    One more thing... I took readings of the usb pins on the mobo for front panel usb and they are @ 5V...
    I was too scared to try to take a reading from the actual usb port. I had a feeling my probe would short out the 5V to the USB casing(assuming it is grounded?)
    Get a usb cable and cut it, then strip the wires inside and test with that.
    Tidder
    Try RevFE
  3. #13
    Sep 2005
    Seattle, WA
    Tidder aka "The man with all the answers..."
    The USB receptacle is a cheaper solution than the PCMCIA card... I just dont know if my onboard USB pins work.
    Looks like I now have a nice set of backup plans if I cant get my rear-USB to work. I was getting really bummed about the situation, so I appreciate all the great ideas.
    B Smoov
  4. #14
    Sep 2003
    New Mexico, USA
    Sometimes I have the answers... it seems today is one of those days.
    Tidder
    Try RevFE
  5. #15
    Newbie 88Vette's Avatar
    Jun 2006
    Houston, TX
    If the USB is not working due to software/drivers issues it won't matter if you plug into the pins on the board and run a new USB jack/header it still won't work.
    If it is the actual USB connector on the rear then yes, this add on idea would work.
    I've never seen a USB connector on a motherboard go bad though...
    Houston, Texas
    eBay:Davidnclearlaketx
    ** 99.5% Positive! **
  6. #16
    Sep 2003
    New Mexico, USA
    I think he's wanting to see if the back ports are jacked or not. Usually there are 2 ports per controller, maybe one of the controllers on the mobo is wasted. From the sound of it, that's what it is. The controller for the back usb ports is effed up. Sounds like he still is getting power back there, just no data. So, good test would be to check the other usb ports via the mobo header.
    Tidder
    Try RevFE
  7. #17
    Jun 2006
    Houston, TX
    Quote Originally Posted by Tidder
    Yep!
    Sounds like a plan!
    It sucks when you have just one thing not working right!
    Houston, Texas
  8. #18
    Sep 2005
    Seattle, WA
    Okay so I bought a USB receptacle and connected it to the mobo pins and it worked...
    I was unaware there are to USB controllers... So either my physical port is messed up or one of my controllers is messed up.. Either way this gets me back up and running which was top priority..
    I'll probably do some further investigation soon.
    Thanks again.
    B
    B Smoov
  9. #19
    Sep 2003
    New Mexico, USA
    Cool beans, at least somethin works.
    Tidder
    Try RevFE
  10. #20
    Nov 2005
    I have the same problem w/ my back USB ports. On my bluetooth device, the light is bright for maybe 1/10th second and then it goes dim.
    The problem started when I somehow managed to short the 5VDC to ground. There was a nice bright flash followed by some smoke. It looks like Ive burnt a resistor or diode out. Neither of the back port USBs work. I just ordered an adapter to try to get the front USBs working.
  1. Epia MII10000 - Sound in *nix, but not windows
    By nyeark in forum General Hardware Discussion
    Last Post: 07-05-2005, 07:23 PM
  2. Epia Mii10000 And A Morex 60w Car Psu
    By Milo in forum Power Supplies
    Last Post: 10-30-2004, 10:17 AM
  3. usb power problem: solved!
    By susman in forum General Hardware Discussion
    Last Post: 08-31-2004, 02:50 AM
  4. Any Epia M10000 Owners Having USB Detection Problems?
    By rgardjr in forum General Hardware Discussion
    Last Post: 04-20-2004, 03:52 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
