Results 1 to 10 of 20
Thread: Via Epia Mii10000 USB
    Maximum Bitrate buurin's Avatar
    Sep 2005
    Seattle, WA
    My USB is currently 'broken'...
    I have a Via Epia MII10000. It has 2 USB ports on the back and I bought an USB hub which allowed me 4 ports. The hub is unpowered and has 2 USB cords going to the CPU, I assume for power.
    Connected to the hub I have: GPS, WiFi, Touchscreen, and a USB extension cord for connecting memory sticks.
    Recently the USB just stopped working after a reboot... My GPS mouse doesnt light up, my touchscreen doesnt work, and my WiFi doesnt work.
    I connected the tocuhscreen and GPS directly to the onboard USB.. Neither worked. When I connect the hub to the onboard USB, the hub's LED lights up but as soon as I connect a device to the hub, the light dims, and if I connect two devices, the light essentially turns off. I dont know if it always did this or not.
    Could I have connected too much to the USB and burnt it out? I say no because the mobo has an onboard connector to add 2 more front panel USB ports... I think. If I did burn it out, is there a fuse? Where?
    Is there an option in BIOS to turn the USB on/off? I havent checked. Maybe it got turned off.
    B Smoov
    Project Status: 90% Complete
    Next Step: TIVO for Radio
    Ampie Case :: MII10000 Mobo :: M1-ATX PSU :: 512MB RAM :: 2.5" HD, 60GB, 5400rpm, 16MB Buffer :: DWW-700H :: Centrafuse
    Elsewhere
    Naw. USB can handle up to 128 devices in a chain, so you're not burning it out or anything even close.
    It's likely USB hub not getting powered so the devices aren't getting recognized.
    I'd pick up some USB ports and conenct them to the extra USB headers ont eh motherboard to see if that is more stable for you.
    How about the Wiki?
    _
    Mar 2004
    Little Elm, Texas
    sometimes there is an option in the BIOS, not sure on your MOBO
    i would try getting a powered USB hub and see if it helps.
    USB it's self does not cary that much current. Over the longer distances that the hub might add, it might not be able to push the current it needs to to all of the devices you are running.
    maybe try a powered hub that's connected to an extension chord first before you hack into it?
    Jan Bennett
    Sep 2005
    Seattle, WA
    Quote Originally Posted by DarquePervert
    Each actual port must be limited though, no? Like I couldnt connect a hub with 128 ports to my usb and expect all devices to be powered.
    Like i said, I connected the devices directly to the onboard rear USB and they were not powered or recognized... This takes the hub completely out of the equation. The problem is with the mobo.
    Quote Originally Posted by Red GTI VR6
    Again... I've taken the USB hub out of the equation by connecting directly to the onboard rear USB of the mobo.
    I think both of your ideas would work well for debugging my hub.
    B Smoov
    Newbie 88Vette's Avatar
    Jun 2006
    Houston, TX
    Go to My Computer>properties>hardware>device manager and see if your USB ports are still showing up.
    Try deleting all the USB ports and then reboot and let Windows find them again for you. Then plug in a device and see if it is recognized.
    Assuming you have XP.
    Good luck. Hope you get it working!
    Houston, Texas
    eBay:Davidnclearlaketx
    ** 99.5% Positive! **
    _
    Mar 2004
    Little Elm, Texas
    let us know if that works for you!
    Jan Bennett
    Sep 2005
    Seattle, WA
    I disabled USB in the BIOS and booted up. USB did not display in Device Manager... I re-enabled USB in the BIOS and booted, and USB shows up on Device Manager... Still doesn't work.. I suppose I will delete USB from device manager and see what happens.
    When I plug my USB wifi into the onboard usb ports, the lights on the USB flicker for a half a second. Normally they would just light up and stay on.
    B Smoov
    Sep 2005
    Seattle, WA
    Where in the world can I get USB ports to connect to the onboard jumper pins usually used to connect to front panel usb ports?
    That seems like my only option.
    B Smoov
    Sep 2005
    Seattle, WA
    One more thing... I took readings of the usb pins on the mobo for front panel usb and they are @ 5V...
    I was too scared to try to take a reading from the actual usb port. I had a feeling my probe would short out the 5V to the USB casing(assuming it is grounded?)
    Anyways... Lets say I never get this working... How could I get some USB? I have an ampie case so the PCI card idea wouldnt work I dont think. But I'd rather switch cases and use a pci card than buy a new mobo.
    Can anyone repair such a thing?
    B Smoov
    Jun 2006
    Houston, TX
    You want to delete all the USB ports in device manager, not BIOS.
    Then reboot.
    If they don't show up and work then you might have to get a serial to USB adaptor or a case you can put a PCMCIA USB card in. They make those cards to go into laptops to give you additional USB ports.
    Keep trying!
    You'll get it working!
    Houston, Texas
  1. Epia MII10000 - Sound in *nix, but not windows
    By nyeark in forum General Hardware Discussion
    Last Post: 07-05-2005, 07:23 PM
  2. Epia Mii10000 And A Morex 60w Car Psu
    By Milo in forum Power Supplies
    Last Post: 10-30-2004, 10:17 AM
  3. usb power problem: solved!
    By susman in forum General Hardware Discussion
    Last Post: 08-31-2004, 02:50 AM
  4. Any Epia M10000 Owners Having USB Detection Problems?
    By rgardjr in forum General Hardware Discussion
    Last Post: 04-20-2004, 03:52 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
