Results 1 to 5 of 5
Thread: What gauge wire do I run?
    Jun 2006
    Arrow What gauge wire do I run?
    I was hoping to use a small wire in my radio harness for the 12v supply, but i think it is an 18 gauge wire...
    Does a carpc psu need thick 4 gauge wire with a 30amp fuse like an audio amplifier would? (coming directly from battery through firewall)?
    Thanks!
    Also, Why do I need a power distro block if I want to power my computer and my amp, cant I just split the power wire??
    Elsewhere
    4awg would be overkill, however 18awg from the stereo harness is insufficient.
    I'd think 10awg from the battery is more than sufficient. AS far as the fuse, you need to calculate the amperage draw and fuse accordingly. There's no one-size-fits-all answer for that.
    How about the Wiki?
    Jun 2006
    Im powering http://shop4.outpost.com/product/458...H:MAIN_RSLT_PG
    and the opus 80w power supply
    will 8awg and 15a fuse be enough?
    also, will i need power distro block and what kind of fuses go in that? thanks
    May 2004
    Denver
    for 80watts, you'd be fine with 12ga... I don't have the site links at work, but 80watts is barely any power draw... essentially the longer the wire run the bigger the gauge you need...
    EPIA SP13000, 512 DDR400, Seagate 300GB, Belkin PCI 802.11g w/external antenna, Holux GM-210 GPS, XM Direct w/ serial, Dlink FM, Opus 120 p\s, Rockford P4004 amp, Xenarc 7" VGA touchscreen custom mounted in double din spot -- see pics and write up here!!
    May 2004
    Denver
    http://www.rbeelectronics.com/wtable.htm
    that wasn't too hard... so let's say you have a 15' run and 80watts... 80/12 = 6.6amps... according to that chart 18ga would do it... 16 and 14 would put you on the safe side...
  1. Alternator Whine Only With Carputer
    By tbird2340 in forum Car Audio
    Last Post: 06-29-2007, 03:36 AM
  2. using speaker wire as power wire
    By michaelrj9 in forum Car Audio
    Last Post: 03-18-2006, 05:08 AM
  3. Replies: 22
    Last Post: 03-09-2005, 11:27 AM
  4. What Gauge Wire To Use
    By owenjh in forum Power Supplies
    Last Post: 02-14-2004, 05:16 PM
  5. Routing power button to front of PC. Can wire be too thick of gauge?
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 09-27-2003, 03:32 PM
