Results 1 to 10 of 14
Thread: Turtle Beach Roadie Review
    Feb 2006
    Durham, NC
    Post Turtle Beach Roadie Review
    I hated my SoundBlaster Live! USB soundcard, and decided to give the Audio Advantage Turtle Beach Roadie USB. Link
    I couldn't find a true review of it anywhere on here (pertaining specifically to CarPC use) so I figured I'd document my thoughts so far. For non-CarPC reviews check this out.
    First, my system specs are in my sig for reference.
    I am by no means an SQ competitor, but I am picky about my sound. I have high quality components and know what they should sound like. I also don't want/need surround sound. I want 4 speaker quadraphonic sound, like a standard deck outputs. So, take this review with that grain of salt.
    Pros:
    -Hibernates with no problems
    -There is no discernable "pop" when the computer finally engages the soundcard. (SoundBlaster’s was terrible)
    -The sound quality seems a lot more powerful than the SoundBlaster. I needed alot less gain on my amps with the unit at full volume to acheive the power I was looking for. And less gain is a good thing.
    - The Roadie, when in 4 speaker mode sends equal signal to all four speakers. There is no simulated surround sound. It seems to do less processing of the signal. I had a problem where the SoundBlaster made it's rear output muddy and clipped in the low range. This does not exist in the Roadie. You get 4 channels of the same signal and volume.
    -The size is significantly smaller than the SoundBlaster.
    -The control panel has, for the most part, all of the options contained in one application. The SoundBlaster had multiple application windows that would pop up.
    -"Per Speaker" equalizer and volume. I have the rear channel feeding my subwoofer, so this means I can change the EQ and volume of my sub indepenent of my front speakers.
    Cons:
    -The unit seems to be USB bandwidth hungry. I had random popping and clicking, like rice krispies in my music. After some reading, I figured out it was because the unit was starved for bandwidth. I added a PCI USB card and dedicated it the Roadie, problem solved. (Note: I switched motherboards at the same time I switched soundcards. The new motherboard could have USB bus management issues. )
    -Some of the sliders within the application are too small to change by hand using the touchscreen.
    -The sliders in "per speaker" EQ screen do not lock to each other for front and rear. I'm not sure of any application when you would want your front/left to have a different EQ than you front/right, so they should be able to be locked together. It's tedious to match them up manually.
    Overall, I would highly recommend the Roadie over the SoundBlaster Live! I have never tried a PCI soundcard b/c of space uses, nor have I used the Audigy, but you can read the woes people have had with that by searching.
    Hope this helps someone.
    _______________________________
    Lilliput 7" touchscreen
    System:
    AMD Athlon XP 1700+
    1 GB RAM
    Windows XP Pro
    Audio:
    Front:
    CDT HD-62 Component Speakers
    MBQuart RAA2400
    Sub:
    Dayton RSS265HO-4 10"
    MBQuart RAA2400 bridged
    Saturated_Fat's Avatar
    Dec 2005
    Rockville, MD
    Thanks dude, gonna order one from mp3car.com's store now. Will post my thoughts when I get it setup.
    Shotgun! - An Advanced CarPC Software Solution!
    Oct 2004
    NY
    I use that sound card too. works great, & I've tried quite a few before this, including the m audio transit.... this one is better that all the rest from what I see..., even hibernates well...
    Feb 2006
    Durham, NC
    Thanks, forgot about the hibernation part, added it to the pros.
    in progress
    Feb 2006
    What is the CPU usage on this guy? I am currently using an epia mobo with a 1ghz chip, and my usb turtle beach amigo eats up nearly 50% of it! I am currently searching around for one that does most of the processing itself and doesn't tax the cpu as I barely have any to spare.
    Is this a good recommendation in that case?
    Thanks!
    Nov 2006
    Monterey Park CA
    I just installed the roadie yesterday, and it's using, on average, 5-8% CPU w/ WinAmp 5.3 & 256kbps MP3 file. I have it connected to its own USB port, as opposed to a hub, per the manufacturer's recommendation, which warns of the problem you're describing when connecting the Roadie to a USB hub:
    http://support.turtlebeach.com/site/.../531418830.asp
    I realize this is an older thread, but thought I should mention it. Good luck with this device. I was one in a growing list of disgusted SB Live owners, and was literally blown away (the output levels are well over twice that of the SB) by the difference.
    Newbie Jakiii's Avatar
    Oct 2006
    Los Angeles, CA
    SPDIF to Analog Out?
    I like the Roadie but I can't make the SPDIF input play through the analog output. Is this even possible? Or is the SPDIF only for pass-through?
    Low Bitrate hookid's Avatar
    Jul 2005
    Denver, CO
    How do I connect my subs to the Roadie. I wanted to be able to control the sub level and im not sure if this sound card will allow me to do that.
    Feb 2006
    Durham, NC
    I don't use rear speakers in my setup, so I just have amp for my subs running off of the rear output of the sound card. Makes it great for controlling the sub level from inside the car. I think you have to have the speaker configuration set to 5.1 to control the sub if you use the subwoofer output of the sound card.
    in progress
    Constant Bitrate diosagain's Avatar
    Feb 2007
    New Jersey
    I have it also but I get that rice krispies popping and I don't know what to do to get rid of it. I don't have room for a pci usb card as my carpc is indash.
  1. New Turtle Beach card?
    By ayclens in forum Car Audio
    Last Post: 01-16-2007, 11:05 PM
  2. Turtle Beach Audio Advantage Roadie USB
    By Saturated_Fat in forum General Hardware Discussion
    Last Post: 06-26-2006, 11:29 AM
  3. Adjusting Volume on Turtle Beach Roadie
    By tjp12100 in forum General Hardware Discussion
    Last Post: 06-21-2006, 04:13 PM
  4. FS: MadDog Geforce FX 5200 PCI, Turtle Beach Santa Cruz
    By blackaccrd00 in forum Classified Archive
    Last Post: 02-17-2005, 04:35 PM
  5. Terratec or Turtle Beach for a sound card?
    By judoGTI in forum General Hardware Discussion
    Last Post: 11-17-2004, 05:11 PM
