http://www.advantech.com/products/PCM-9572F.asp
This one has everything you've stated, but it's not cheap. Direct from Advantech this if $870, includes on onboard P3-500 CPU.
Ok it is time for my next box
I might be going the SBC way this time. I want a SBC atleasta pIII 500+ mb
1) It must have TV-OUT!!!!! a must!
2) It must be capable of playing DVD's!!! another must!
3) It must have USB
4) DOC is ok, but not a must....
5) It must have atleast 2 ide... HD + CDROM!!!! a must
6) It must have onboard sound...
7) Power....from what i see so far it looks like most take from 5/12v at diff amps so thats a diff story!
8) Last but not least it MUST BE SMALL.
9) oohh optional PCI....
I hope i didnt miss anything... I need this info ASAP so i can start drawing things out
abcd-1
how did i miss that....what else is out there
abcd-1
Here is the one I would get....
http://www.emacinc.com/pc_compatible...o/pcm6890b.htm
It is $469.00 on this site but someone said you could buy it cheaper somewhere else...
Still, $469 sounds like a great price for what it does!
This will be my next car pc for sure!
Mike
yikes...getting better...
now can that one handle DVD????
abcd-1
I dont see any reason it wouldnt with the right chip (p3 800) and enough ram
Hmmm....its either i am looking at the wrong board or something else. D/l the *.pdf file, it says it only support Celeron 300-444mhz
abcd-1
A more cost effective offering from Advantech would be the PCM-9574. At only $435, this sucker packs quite a punch.
EDIT: No tv-out on this board, but who needs it when you've got a flat panel controller? It's probably available as an option if you call them.
abcd-1
