For any of you with a wintv-fm USB, have you experienced a "POPPING" sound each time you turn the tuner on or off? Also depending on the software you are using (the one that came with the fm tuner - wintv fm) pops every time you try to select a memory preset. THIS IS SO ANNOYING!
I searched to see if anyone had this issue but found nothing.
The only way I can think to fix this is to mute the line-in on the sound card whenever a keyboard our mouse event is sent to whatever application is controlling the fm tuner.
I know this can be done with the windows API using hooks, but I am not the best programmer.
Any input is appreciated.
