Results 1 to 10 of 17
Thread: Rearview switching for a Xenarc?
    _
    Mar 2004
    Little Elm, Texas
    I've done a bit of searching, but can't find anything specific to the Xenarc, only to the Lilliuts.
    Does something exist out there already or is it mostly a do-it yourself jobbie?
    Picking up the reverse lights signal is easy.
    Does the Xenarc have a wire that will auto switch to video instead of VGA?
    Jan Bennett
    Maximum Bitrate Rundell's Avatar
    I remember reading it somewhere on here that it will automatically detect video signal and switch over and then turn back over to vga when the signal is off. I could be wrong though
    Remember AllAdvantage From 7 years ago? IT IS BACK! Now under a new name Agloco
    GET PAID TO SURF THE INTERNET
    _
    Mar 2004
    Little Elm, Texas
    so then putting a relay on the reverse light wire would be all that's needed.
    when the relay flips, it turns the camera on, thus sending a signal to the screen which causes the video input to switch to the input that the camera is on.
    Am I thinking this through correctly?
    Now to figure out which camera to use.
    I haven't seen many people implement this on here, which makes it difficult to find a good camera...lol
    Jan Bennett
    Maximum Bitrate techy101's Avatar
    Minneapolis, MN
    I did this on someones car a year or two ago. IIRC I had the camera turn on via the ACC wire, and was on the whole time the car was on. Then I put the relay control on the video line itself. The distortion was minimal if at all. The relay was fired by the reverse lights like you mentioned.
    I forget the setting, but it's in the menu somewhere. Just turn it on, and when it detects video it will switch by itself. I'm pretty sure that it is set to work on the video 2 input.
    Hope that helps. Sorry I can't be more specific, but it's been a good while since I did it.
    I chose to do it this way instead of the way you're talking about because that meant that I didn't have to wait for the camera to power up, etc... when switching to reverse each time. Plus I split the signal into video one pre-relay, so I could manually view the camera if I so desired w/o having to be in reverse.
    EDIT: Oh, and I just noticed that you've got the Focal Beryllium units. I just want to say that I'm extremely jelous. A number of the cabinets that I use at work have Beryllium Compression Drivers in them, and they sound like a dream. What did they do to get around the fact that Beryllium is toxic if it's aspirated (i.e. you wreck, and it shatters, and gets into the air)?
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    The Xenarc has the feature built-in. I tested it once to see if it works and it does. I haven't purchased a camera yet to install but I picked this one after reading reviews in some other threads on here:
    http://www.mp3car.com/store/product_...roducts_id=166
    ~Jimmy
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by techy101
    Sweet! Now to just figure out where to actually MOUNT the camera...lol
    Now I have something to do while at work tomorrow! Yippee!
    Helped a great deal, thanks!
    This is a valid point and one that just crossed my mind a few minutes before checking my email to see that there were some responses to this thread!
    I don't think they have done anything...lol
    Seriously, when I got the tweets, they came with a baggie and a sticker. They have some documentation that tells you that if you scratch the face of the tweeter, immediately remove the tweeter from the car, put the sticker over the face to seal it off, then place in the baggie and ship back to France.
    Scarry stuff!
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by JimmyFitz
    Sweet! Thanks for the link Jimmie.
    You wouldn't happen to remember if it takes a setting like techy101 mentioned in the screen would you?
    Jan Bennett
    Minneapolis, MN
    Quote Originally Posted by Red GTi VR6
    Scarry stuff!
    I'd have a hard time putting one of those in my car I think. We don't worry about it with our cabinets because they're flown at (most of the time) a 15-40 foot trim. So by the time it reached the audience level it'd be so dissapated it wouldn't matter. Although I'm not exactly sure how you'd rip it apart to replace the unit in the shop. *puts on radiation suit*
    I'm interested in how well they implimented them, compared to say a high end soft-dome.
    Sorry for the thread jack.
    _
    Mar 2004
    Little Elm, Texas
    tell ya what, when I talk to Duane or Jesse or Nick next time at Orca, I'll ask them about it.
    I've been curious myself, just never bothered to ask. Was too grateful to have the chance to run them...lol
    Jan Bennett
    Nov 2005
    Austin, Texas
    It has been a few months since I did it. You have to have it on the correct input and have a screen setting to recognize it. I think it didn't work when I first set it until I power cycled the screen. After that it worked automatically when the input was detected.
    ~Jimmy
  1. Xenarc RCA Switching Bug Question
    By EricE in forum LCD/Display
    Last Post: 05-16-2006, 12:05 PM
  2. Xenarc TSV 700 Not switching inputs
    By zaid175 in forum LCD/Display
    Last Post: 07-21-2005, 04:02 PM
  3. xenarc first impressions, tried lilliput before
    By emdzey01 in forum LCD/Display
    Last Post: 06-09-2005, 07:26 PM
  4. Replies: 88
    Last Post: 09-15-2004, 06:38 PM
  5. Xenarc Meta FAQ
    By Skippman in forum LCD/Display
    Last Post: 08-23-2002, 04:11 PM
