I know exactly what you mean.
An idea for you to consider...
Get a case, and drill holes on the cover for the buttons... place the buttons directly under the holes (from inside the box)... hopefully u have enough key button shaft length to get just EXACTLY to the surface of the cover of the case. You dont want it to stick out too far... otherwise it will make a bulge when u do the steps below. If your button doesnt have a very long shaft... (from the looks of that picture u posted... im thinking yes...) u can add a spacer.
Then place a sheet of transparency or such... and over that goes a good thick piece of white paper... with boxes and characters inside them... (printed out with a computer).... place this over the transparency... then another clear transparency over that... (so u dont wear out the paper/printed surface...
The lower transparency protects the paper from wearing out by the button surface... the top one protects from your hands.
By pressing the appropriate "box" you press your respective button...
This basically immitates the way the device you posted operates.
I hope you can figure out what i was talking bout from my 2 min mental blurb...![]()
LinkBack URL
About LinkBacks
good luck!
