Results 1 to 2 of 2
Thread: Stepping-up power supply?
    May 2000
    Question Stepping-up power supply?
    Anyone know How I can make a power supply that steps up from the car battery? Kinda like a power supply for the Netpliance power, or for the miniPC (which takes 18V@3A)
    Free entrance to heaven? WOW! I DUN BELIEVE! JC!
    Aug 1999
    Yorba Linda, CA
    Sure, you just need a step-up switching regulator circuit. Check the MAXIM website ( ). They have several ICs that should do the trick. Check the application notes section as well as the datasheets for some of their step-up switching regulator ICs -- these often have example circuits you can copy to make your life easier.
    If you don't want to build your own, you may want to look into a DC-DC converter module or board. Check the surplus places like All Electronics ( ) or MPJA ( ).
    Jason Johnson
    Yorba Linda, California
    MPC Phase IV - *** PENDING ***
