Results 1 to 9 of 9
Thread: Panasonic Slot-Load Problem
    Apr 2005
    Queens, New York
    I just recently installed my slot load cuz i was too lazy to hook up a 5v line to it since it would poer off a usb hub. But ther 1st couple days it worked fine but now when i put any type of cd in the carpc kinda freezes but i can ctrl + alt + del and end the process. THe pc will not read any cd / dvd anymore. ANy reason for this? Also if i try to eject the cd by pressing the button it wont eject .
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    Variable Bitrate NeoMatrixJR's Avatar
    Aug 2004
    Arround Des Moines, IA
    I don't know if you have the same model I do, but 1.) I HAD to hook up 5V power AND the USB because if you check the power requirements on the drive it's up to 2 amps and you're usb hub typically only supplies that, so if you have other devices plugged in...good luck getting enough power. 2.) the eject button never worked. Mine even has the apple logo. These drives I believe are surplus from Mac Mini's and MM's don't have eject buttons on them if I recal. The hardware eject buton has been disabled and glued in so it could sit up flush in the mac. You have to use a software eject in either My Computer (right click the drive), or RoadRunner's built in eject, or if you PM me I can send you a standalone eject.exe that came w/ my drive.
    Apr 2005
    Queens, New York
    Quote Originally Posted by NeoMatrixJR
    Sorry i forgot to specify that I DID supply a 5v line recently because it woildnt work without 1. But now the pc reads the drive but just doesnt read the cds
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    mine wouldnt come up in windows at all. lol.. go figure.. but strangely it works on my home PC... dont know why. but it just does.
    Carputer HIFI car stereo project!
    [XXXXXXXXXXXXXXXXXXXXX-]
    95% COMPLETE! FINALIZING SOFTWARE PLATFORM!
    [XXXXXX--------------]
    30% COMPLETE! CAPUTER Version 2.0! Hardware FAILING! CARPUTER BLEW UP! AND NOW MONITOR TOO! WTF?!
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    mine did it before, I had to reinstall the drivers for the drive. If you check your device manager in the control panel to see if it working right.
    i dont think mine came with any drivers. its in an external usb box..
    Aug 2004
    Try this bit...I posted this response to another thread...it may help...it was the other problem I had with mine.
    If you take the housing off of the drive you should see (if yours is set up like mine was) a converter board(s) that go from the cd-rom's ATA to USB. Now on mine there was one thin board that ran across most of the back of the CD drive and was held on to a second board (that contained some caps and the USB connector) by few small solder points and nothing else!. What I actually wound up doing to mine was bending very small sections of a paper clip (something sturdy not weak ones) at 90 degree angles and soldering them into the connections and then JB Welding the USB board to the CD-Rom drive so it wouldn't move. I found after inserting and removing the USB cable too many times those solder points broke.
    Go give that a try and see if that fixes it.
    hmm lol that would work if it wasnt stuck in my dash.. haha.. oh well...
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Had the same issue, basically fixed it the same way, except I used some double stick foam tape, and put it between the board and the CD driver, and between the board and the plastic housing.
    Michael
  1. FS: Panasonic Slot Load DVD burner
    By EsKALad in forum Classified Archive
    Last Post: 03-18-2006, 02:36 PM
  2. FS: Panasonic Slot Load DVD-ROM/CD-RW Combo Drive 24x24x24
    By kickercivic1 in forum Classified Archive
    Last Post: 10-16-2005, 09:28 PM
  3. FS: Panasonic UJ-815B DVDRW/CDRW
    By A-Z in forum Classified Archive
    Last Post: 10-03-2005, 03:16 PM
  4. Slim, slot load, DVD drive, where to get one??
    By JonEQuest in forum General Hardware Discussion
    Last Post: 06-23-2005, 02:58 PM
  5. Pioneer Slot load 120S - modification
    By brrman in forum General Hardware Discussion
    Last Post: 01-03-2005, 12:25 PM
