Results 1 to 7 of 7
Thread: New OPUS MINI ITX Case
    Apr 2005
    Queens, New York
    Does any1 know the exact height of the newere OPUS mini itx pc case? I know that the dimensions are wrong on opus' website.
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    Variable Bitrate walstib's Avatar
    Jul 2005
    Atlanta, GA
    Is this the newer one?
    Carputer Project Status:
    0% - Mobo died on 2/17/08
    Check out the worklog for my '01 Pathfinder.
    Apr 2005
    Queens, New York
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    _
    Mar 2004
    Little Elm, Texas
    oooo - very cool design!
    sorry - no info on the height though!
    Jan Bennett
    Apr 2005
    Queens, New York
    Yeah it is a nice design, I have he older opus case. BUT I went to try and mount it under my seat but it is too hight by like a 1/4 inch cuz there is this bar on the bottom of my seat so when i move the seat back and forth the bar will hit the case. I am going to see if maybe I can raise the seat i dunno...
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    _
    Mar 2004
    Little Elm, Texas
    Reasons for not installing anything underneath the seats.
    • There is no place to properly ground anything underneath the seat. Most people would try and use the seat bracket bolts. These are not good grounding points for a few reasons.
      - Usually these bolts are covered in grease, grit, or grime, thus making the ground a bad ground.
      - These same bolts are usually covered in paint, as is the threaded part that the bolt goes into.
      - Those mounting points usually have carpet underneath them, meaning that the ground is not solid.
    • That dirt, grit, and grime got there somehow. That same dirt, grit, and grime will get in whatever piece of electronic equipment you put underneath the seat.
    • If passengers can see it, they will mess with it. I know that we all like to think we can trust our friends. The fact of the matter is that people are curious. If they see a bunch of wires sticking out they will play with them. Not only will you risk having your passengers pulling things apart, you also risk them shocking themselves. Though you might think “Good, they deserve it then”, you can still be held liable. Sucks, but that’s the truth.
    • Even if you ask people to watch their feet, it’s like a magnet. Their feet will find their way under the seat. In doing, so they will break wires, break solders on boards, and introduce all kinds of foreign objects from their shoes that you don’t want around electronics.
    • The seat moves, you can try all you can think of, but it moves. There are things beneath the seat that will catch wires and pull them out. Moving pieces are never a good thing to mount next to or around unless you have the proper materials, and 9 times out of 10, you won't.
    Jan Bennett
    Apr 2005
    Queens, New York
    Thanks got the tips RED!!
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  1. Carputer Opus Case
    By Cheekz185 in forum General Hardware Discussion
    Last Post: 06-22-2005, 03:03 PM
  2. mini itx case.
    By kilomo in forum General Hardware Discussion
    Last Post: 12-30-2004, 06:54 AM
  3. WTB: Opus 90W, ITX case, VIA M10000
    By Uconnputer in forum Classified Archive
    Last Post: 12-13-2004, 04:28 PM
  4. Mini ITX in car stereo?
    By ljstevens in forum Newbie
    Last Post: 11-26-2004, 10:56 AM
  5. Mini itx case
    By Cris in forum General Hardware Discussion
    Last Post: 06-29-2004, 06:12 PM
