Results 1 to 5 of 5
Thread: Noise From PSU Through Wired FM Modulator
    May 2005
    I have an EFM-01 wired FM modulator installed. Whenever the computer is turned on the radio station goes from crystal clear to really fuzzy. Im pretty sure its my M2-ATX. Ive tried using a different 12v source and ground and it was all the same. I even tried putting tin foil around the computer and FM Modulator to see if it made it difference, nothing noticable was achieved. Any ideas on how I can fix this? Its stressing me out. Without the PC on, ie an iPod input, it sounds GREAT. When the PC is on from either the PC or an iPod its barely audible. Any suggestions would be much appreciated!
    May 2005
    I've determined its definetly the PSU making the interference. How can I reduce the emission? I tried tinfoil but that didnt work. I know most PC's have that metal shield that comes out but.. would it just work to cut that up small and put that around the M2?
    FLAC SnyperBob's Avatar
    Nov 2001
    Just wondering if you've searched or hit up the FAQ section? This is the most common problem for everyone here, that uses an FM modulator.
    My recommendation: Check the ground on your power supply, inverter, and fm modulator. Is it grounded to bare metal? Are they grounded to the same point? Are you using a ground loop? etc...
    Free file hosting, picture gallery hosting for installs, PM me.
    Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
    May 2005
    I checked the FAQ. I thought most of the problems were due to alternator noise with the matching RPMS and what not. Ill check again. Thanks
    Variable Bitrate wallaceacura's Avatar
    May 2005
    SE Wisconsin
    I just installed a FM modulator, DVD player and LCD screen in my wifes truck yesterday, all grounded and powered from the same locations. Should they not all share a common ground? The modulator is grounded to a metal cross bar under the steering column (not bare metal). The volt meter read same as if it were bare metal, if it makes a difference? I don't have a PSU in the car.
    Biostar M7NCG 400 ver 7.2 AMD Mobile Athlon 1.1GHz (@ 1GHz), Kingston PC2700 512mb WD 80gig HD Custom Case Opus 150W PS Lilliput 7" TS D-Link DBT-120 BT D-Link DWL-G122 WiFi Holux GR-231 GPS nLited XP Pro iGuidance RoadRunner frontend
  1. Troubleshooting: NOISE
    By RedGTiVR6 in forum Car Audio FAQ
    Last Post: 03-26-2005, 11:31 AM
  2. USB FM modulator.
    By ppgt94 in forum General Hardware Discussion
    Last Post: 10-01-2004, 03:24 AM
  3. FM Modulator issue!
    By skotte in forum Car Audio
    Last Post: 09-22-2004, 05:45 AM
  4. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
  5. Which one is better? FM Transmiter or FM Modulator
    By helloman in forum General Hardware Discussion
    Last Post: 03-12-2001, 10:15 AM
