Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: mini-itx w/dual display?
    is there any way to have a mini-itx board with dual display support? would i'd need to use the pci slot for it, that is the only way i can think of it supporting dual display. i dont mind having one vga, 1 composite out, does the via mini-itx boards allow the use of the tv-out and the vga to be used at dual displays (extended desktop not like mirror display). on the same note, i want to use one screen to display the front end and the second screen to display vehicle diag info
    Vendor - Mo-Co-So
    Nov 2005
    you can do a split screen with a VGA splitter/booster and windows. XP supports it.
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Dont' know what VGA splitter/booster he's talking about, but I think pretty much the only VGA alternative out there is Matrox's Dual-Head 2 Go.
    http://matrox.com/graphics/offhome/dh2go/home.cfm
    This setup lets you do extended desktops, which you may be able to do what you want with.
    Variable Bitrate inniss777's Avatar
    Oct 2003
    SOCAL
    Matrox's Dual-Head 2 Go is a peace of sh#t
    It's a great concept but it lacks support. It's really picky about the chipset you are using and sometimes it doesn't work on the chipset it's capatible with. Also you have to run your res at 1024 *768 per monitor. The only realiable solution is to use a pci dual video card. Disable the onboad video and run both vga video from the card. Depending on the board some via boards will not handle dual support very well. I tried it on a M2 K with 64mb of video ram and the cpu % was about 90 or more most of the time while running video on one of the screens. I used the same board in ibase 896 with 1.73 pentium M and the cpu usage was about 25%. Also since most vehicle power supplies can not handle the real high end pci graphic cards I recommend 128mb or less and with out a fan on the card.
    Opus case. MB 899 core duo 2.0ghz
    Dual vga out, 400 gb hard drive, Centrefuse front end
    zapco 1000.4 for zapco 6.5 componets
    zapco 1100.1 for 2 13" W6.
    Feb 2005
    I agree with the above, no where does it list the graphics chips used on any of the EPIA motherboards as compatible on the website. I would have to pass until someone proves it works.
    Brent
    1999 Nissan SE-L - turbo toy
    1993 Nissan NX - Turbo Racer
    Standalone fuel management (AEM EMS) on both
    carPC
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    Well dual display worsk on the MII 12000 board but the only problem is that it doesn't have alot of options. Like I am using RR and want to be able to view dvd on the second monitor but RR will not allow it to display on the second monitor. RR takes control of it.
    Dec 2008
    Thread resurrection
    I found this thread while searching for Dual Display Options (after having searched for all other variants of the subject).
    Are there any updates to this topic? I'm looking for a mini-ITX solution that will allow me to run 2 touchscreen monitors (both lilliput if it matters). So I will need 2 VGA outputs. My plan is to have GPS or gauges on the upper monitor and the music playback front end on the lower monitor.
    What's the best way to accomplish this?
    I do not want to use anything larger than Mini ITX and I do not want to run 2 car computers!
    Dec 2007
    most will have a dvi and vga, so you will need an adaptor and then you will have dual vga, note though it will have to be a nvidia or ati/amd setup, as they will probably have it, not sure if intel makes dual video's but it might have. My money is on geforce/ati
    Oct 2006
    Here is another solution:
    http://www.ncix.com/products/index.p...nufacture=eVGA
    since its usb it'll use the cpu's resource.
    Variable Bitrate Deric's Avatar
    Sep 2006
    We've used the usb VGA adapters at work and they do pretty well. I don't know how they would work with DVDs though. You might also look at the new USB monitors. It might be cheaper than a USB adapter and monitor solution.
  1. Mini ITX CarPC for sale
    By breaker021 in forum Newbie
    Last Post: 04-12-2005, 07:35 AM
  2. Mini ITX CarPC for sale - cheap!
    By breaker021 in forum Classified Archive
    Last Post: 04-11-2005, 04:09 PM
  3. FS: Fully Built Mini ITX System
    By twistywizard in forum Classified Archive
    Last Post: 01-02-2005, 08:04 AM
  4. mini itx case.
    By kilomo in forum General Hardware Discussion
    Last Post: 12-30-2004, 06:54 AM
  5. mini itx and xp
    By oddcomp in forum General Hardware Discussion
    Last Post: 09-16-2002, 03:20 PM
