Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: my computer wont boot to windows, says "Boot From CD :"
  1. #11
    Variable Bitrate shrinkydinx's Avatar
    May 2005
    Quote Originally Posted by tj!2k4
    if you're using the PS2 mini keyboard, I'm pretty sure it has a del key.. I believe you had to use the Fn modifier, though.
    if it does, its not labeled...
    carputer - done.
  2. #12
    Raw Wave tj!2k4's Avatar
    Oct 2004
    sorry, i was thinking of the "backspace" key (symb + spacebar).. my bad.
  3. #13
    May 2005
    problem solved -
    after i changed the boot device order (for some reason USB FDD was #1, i would never have set it that way) to put 'Hard Drive' as #1 it still didnt work, but only said "Building DMI Pool" with a flashing cursor under it...
    then i checked the Hard Drive boot priority, and for some reason they were also out of order, so i put my boot drive as #1, and then rebooted, and it worked
    hope this helps in case anyone else has a similar problem...i dont know why it all got switched around...
    carputer - done.
  1. Replies: 2
    Last Post: 06-02-2006, 01:42 PM
  2. Windows XP won't boot up anymore!!!!
    By Luderboy in forum Newbie
    Last Post: 09-03-2005, 06:03 PM
  3. How to optimize Windows XP boot times
    By 12Vsystems in forum WinNT Based
    Last Post: 05-12-2005, 11:36 AM
  4. I cant get my computer to boot my CF Card
    By csnowman00 in forum General Hardware Discussion
    Last Post: 03-15-2005, 12:10 AM
  5. How fast does your computer boot?
    By gardocki in forum Newbie
    Last Post: 03-09-2005, 03:17 PM
