Results 1 to 10 of 16
Thread: video signal mirroring?
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    has anyone found a way to inverse (mirror) a video signal from a camera??
    i have found those cheap IR cameras (25-30 euros) and would like to use them as reverse camera!! but they do not inverse the image
    _
    Mar 2004
    Little Elm, Texas
    most people go ahead and purchase the cameras that have it built in. One thing I would worry about is the picture quality on one of those cheap cameras.
    is it CCD?
    Might want to read up in this thread to learn a bit more about the cameras and the different options avaliable out there:
    Reverse camera options
    Jan Bennett
    Apr 2006
    Greece
    yep it is a ccd it is even advertized as a 0 lux!!
    it is the "ztv 812"
    i found it in carefour
    http://www.amazon.com/gp/product/B00...lance&n=172282
    _
    Mar 2004
    Little Elm, Texas
    hrmm - wireless running off of a 9v battery?
    scarry IMO
    Jan Bennett
    Oct 2004
    NY
    there is no simple way to mirror the image...
    it is not the same image as the pixels your used to.... composite uses a scan from top left start, to top right, back to left one later down, back to right, & basically zigzags across the screen till it reaches the end, bottom right... then starts over
    to flip the image you have to alter the scan.... if it started from right to left, it would be mirrored, but this can't just be done in line.. it would be very complicated, basically the signal would need to be converted to digital, then altered... you can do this on your pc... but for a mirror image on a composite screen you will either need a camera that does mirror image or use a multiplexer that supports mirror image... or a screen that does mirror image..natively at the display itself...
    Oct 2004
    NY
    that camera looks like crap also... the 0 lux rating is bs... the only reason they are advertizing 0 lux is AFTER the infrared assist... ANY camera will be 0 lux with infrared assist... that means nothing...
    Apr 2006
    Greece
    Quote Originally Posted by turbocad6
    yea i know.. ofcourse 0 lux is with ir support.. but the same camera with the same characteristics is sold on line "for the car pc market" 70-80-90 euros.. that is my point..
    i understand that image mirroring is not very simple but what the heck , this forum has solved more complicated problems
    _
    Mar 2004
    Little Elm, Texas
    are you absolutely positive it's the same camera?
    Jan Bennett
    Apr 2006
    Greece
    Quote Originally Posted by Red GTi VR6
    ofcourse not
    same specifications though..
    many things are overpriced when they have the title "for automotive use"!!
    have seen it before.
    _
    Mar 2004
    Little Elm, Texas
    same specs?
    *sigh*
    no, just because it's the same specs doesn't mean it's even close to the same thing.
    Many times, things for the car are overpriced because they have to be ruggidized. That costs money, usually quite a bit of money. Just for starters.
    Go ahead and get the camera. Since it's wrong of someone to try and save you money and keep you from making a bad decision/bad purchase, I'll refrain from going any further with you.
    Jan Bennett
  1. *****FS: 1 into 6 Video Signal Amplifier*****
    By BIzFlawless in forum Classified Archive
    Last Post: 06-20-2006, 03:37 PM
  2. video wont display when entering video mode ?
    By Coldfusionpower in forum LCD/Display
    Last Post: 05-21-2006, 01:36 PM
  3. No video signal unless I hit reset switch - why????
    By hd54321 in forum General Hardware Discussion
    Last Post: 04-17-2005, 11:52 AM
  4. Extreme video playback choppyness with HVAC software
    By Dexter in forum Software & Software Development
    Last Post: 04-11-2005, 02:24 AM
  5. Video signal for 2x LCD's on xbox?
    By dr_k in forum LCD/Display
    Last Post: 03-29-2005, 09:08 AM
