Results 1 to 8 of 8
Thread: Thumb Drive as boot drive??
    Mar 2005
    SO I know there are some impressively large USB Thumb drives out there.. I've seen them up to 8GB.
    So my question is, could I use an 8GB Thumb Drive as a primary hard drive? Boot a windows OS off of it.. then use a secondary hard drive for storage of all my programs and what not?
    I'm really just looking for an ultra-fast boot up/hibernate solution with out having a horribly stripped down worthless version of XP.. or Vista..
    So what are my solutions??
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    SATA?. Booting off of USB, esp flash media, is slow. You won't find a USB device that'll beat a SATA (or IDE I would think...) in boot times. Believe me, I've been down this road. Just use hibernation or standby and you'll be fine. Plus if you go flash, you'll have to make your OS read only, which is kind of a chore in itself. It's just a better choice to use your HDD for everything if you plan on using one anyway.
    Tidder
    Try RevFE
    Mar 2005
    So SATA.. Maybe then SATA in RAID0 config... or maybe just 1 raptor 10K?
    Sep 2003
    New Mexico, USA
    Naw, I wouldn't do raid in a car, or a raptor either, I haven't seen any amazing speed increases from those raptors. I think it's a load of crap personally. What's your other system specs that you're thilnking about/have?
    Tidder
    Try RevFE
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    what do you want to gain over using a regular harddrive?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Mar 2005
    Just fast boot/hibernate times.
    When I go into standby the computer barely takes any juice right?
    FLAC SFiorito's Avatar
    May 2004
    yes, you can boot XP from a flash drive. it's very fast if you use the right drive. no spin-up, or seek time makes up for the slower transfer speed. I've used a couple different USB devices and it's possible. Standby is nearly instantaneous due to no waiting on the harddrive to spin up.
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Using a SanDisk Extreme III Compact flash card my OS boots to Shell in about 7 -10 seconds. Thats including BIOS, the shell takes an additional 7-10 seconds to load, the shell is on an IDE drive.
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
  1. FAQ: How to install a DVD R/RW in your Xenarc 700IDT
    By cdcamaro9534 in forum The FAQ Emporium
    Last Post: 12-10-2007, 01:34 PM
  2. 2.5" drive help?
    By IntellaWorks in forum General MP3Car Discussion
    Last Post: 10-03-2005, 08:36 AM
  3. USB Thumb Drive Thought
    By jcdillin in forum FrodoPlayer
    Last Post: 03-08-2005, 06:12 PM
  4. XP on CF II Drive
    By NOS TANG in forum Software & Software Development
    Last Post: 11-30-2004, 02:20 PM
  5. thumb drive error
    By LudeAtude in forum General Hardware Discussion
    Last Post: 03-13-2004, 02:28 AM
