Results 1 to 2 of 2
Thread: Extending USB
    Jul 2006
    Extending USB
    I've found threads on here where cat5 cable is used to extend your USB connectors. I don't understand how that is done. The USB connections that connect to the motherboard use 9 pins. Correct if I'm wrong, but a cat5 cable only has 8 wires. How do i get this accomplished? I'm quite confused on what needs to be done. If someone can point me to a thread that I might have overlooked in my search or some website that gives detailed instrunctions how to do this.
    Thanks for the responses.
    Kenny
    Elsewhere
    Actually, if you look closely, only 8 of the pins are used, and two of those are grounds, and can be shared.
    How about the Wiki?
  1. USB IR stick to COM port??
    By vxcarpc in forum Input Devices
    Last Post: 03-20-2008, 07:31 PM
  2. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  3. USB sound + USB DVD = SLOW
    By TimW in forum General Hardware Discussion
    Last Post: 06-23-2006, 02:19 PM
  4. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  5. are usb 2.0 devices able to work with usb 1.1 hubs?
    By chris in nh in forum General Hardware Discussion
    Last Post: 06-28-2004, 08:27 PM
