Results 1 to 3 of 3
Thread: Inverter
    Apr 2005
    Queens, New York
    Inverter
    Hey guys, I want to get something that basically if i bring my carpc into my house i can hook up power/ground to an inverter and the inverter plugs into the wall for power. So i dont have to keep opening up my case and connect a desktop pc PSU to my mobo and blah blah blah.
    WOuld this work or is it the opposite?
    http://www.radioshack.com/product/in...entPage=search
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    FLAC evandude's Avatar
    Mar 2005
    Maine
    inverter is DC to AC, not the other way around. you need a 12v (or 13.8v) AC-DC power supply. for instance, if you search radioshack's site for 'power supply' the first three results are 13.8v power supplies, designed to run car accessories indoors, the first one being 15 amp output which should be more than enough for your system.
    you can probably do much better on price on ebay or elsewhere, rat shack is usually a ripoff.
    I won't flame you for it since you have over 900 posts, but you really ought to read the FAQ where this is covered see post #3
    FAQ: Power Supplies Explained (Part 1)
    as a cheaper alternative, if your carPC doesn't use a ton of power, you might be able to hack a regular ATX supply and get +12v from it to power your PC; but depending on the ATX supply, it might only be able to provide 6-10 amps; for your epia system that should still be enough, but you should do some quick back-of-the-envelope calculations to double check.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    Apr 2005
    Queens, New York
    Quote Originally Posted by evandude
    Opps lol sorry bout that!
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  1. Problems I've had with inverter (Sima 300w - 600w)
    By dagnasty in forum Power Supplies
    Last Post: 01-21-2006, 10:13 AM
  2. inverter startup prob~!
    By bulgogi777 in forum Power Supplies
    Last Post: 10-15-2005, 03:20 PM
  3. Replies: 5
    Last Post: 02-04-2005, 11:07 AM
  4. relay, inverter, fuse problems
    By cheesyhoward in forum General Hardware Discussion
    Last Post: 06-22-2004, 04:05 PM
  5. odd inverter behavior
    By jshrieve in forum General Hardware Discussion
    Last Post: 04-10-2001, 05:53 AM
