Results 1 to 3 of 3
Thread: Does the computer case have to be grounded to the chassis? Why not float it.
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Hi.
    I have not yet installed a carputer yet, and I am still in my planning stages. I have a computer set up and I tried powering it off my inverter to test everything out. The inverter was powered off a ATX computer power supply so I could see if the computer would run from the inverter off a 12 volt supply ok. The inverter I am using has its AC ground plugs not connected to anything and I was wondering if this might be a problem to my computer if it were to be used in my car (static electricity maybe?). I have read alot about people connecting their computer's case to the car chassis for ground. However, when I connected my multimeter to my computer case and the negative terminal on the inverter, it showed an electric potential of 0.1 volts. Should I still ground the case to the chassic of my car when I install the computer? The computer runs fine without the case grounded, so maybe should I just leave it that way?
    Elsewhere
    If it works, don't fix it.
    How about the Wiki?
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    Some AC inverters don't ground their outputs properly...that's likely why you are seeing a voltage difference.
    I found a 20 volt (!) difference between my chassis ground and my inverter ground...and I wasn't aware it existed until I noticed that everytime I touched the any audio or video ground connected to the computer and my metal gearshift at the same time, there was a nice tingle that ran up my arm. Thank goodness it was only 20volts...
    I agree with Darque. Don't fix it.
  1. Painting Ampie Case
    By semovodka in forum General MP3Car Discussion
    Last Post: 10-08-2005, 05:37 PM
  2. Wanted! : Small computer case
    By Dimitris1976 in forum General Hardware Discussion
    Last Post: 04-25-2002, 09:27 PM
  3. how does my computer case look
    By allenruble in forum General MP3Car Discussion
    Last Post: 02-20-2002, 07:04 AM
  4. Plexiglass computer case???
    By donalson in forum General Hardware Discussion
    Last Post: 12-04-2000, 07:12 PM
  5. computer case
    By Nutzy in forum General Hardware Discussion
    Last Post: 01-16-2000, 10:33 AM
