but power consumption will be high if i buy ant other AMD or INTEL Proccy.
its ok it better be cheap, sub 100 if not its not worth it much, because any other amd/ati combo will be way more then what you need but at least you will get what you payed for, and you can always tweak it
a BE amd chip u can undervolt and underclock to be a mobile chip and its far cheaper then anything that intel has and far more powerful then any atom
no because you get a high clocked cpu that is say 45 or 65w stock, but you run it say 1ghz lower and undervolt it almost to the min of your mobo and then bingo you have a mobile chip, still much faster then any atom
i have seen ppl do this also even with quad core, but i think that is pointless 2 cores is more then enough, 1 is so so
i havent used 1ghz ram, cause the mobo i was talking about was fit with (800mhz) x2, but now there are low wattage x3's and x4's which is really nice, no mater what anyone says that extra cache and extra cores help in boot up time as well as faster ram ht etc...
x3's and x4's are now cheap enough to use and low power enough 65w to use in carpc
Were can I find any of these AMD CPU with suitable HSF? I cant find any sellers here in Sydney Australia
AMD Phenom X4 9350e 2000Mhz 512KBx4 2MB Agena 65nm B3 65W 3200 V1.4
AMD Phenom X4 9450e 2100Mhz 512KBx4 2MB Agena 65nm B3 65W 3600 V1.4
AMD Phenom X3 8450e 2100Mhz 512KBx3 2MB Toliman 65nm B3 65W 3600 V1.4
Would be nice to find these ones too..
AMD Phenom II X4 900e 2400Mhz 512KBx4 6MB Deneb 45nm C2 65W 4000 V1.4
AMD Phenom II X4 905e 2500Mhz 512KBx4 6MB Deneb 45nm C2 65W 4000 V1.4
New Car PC Build list in progress
I found the CPU i would like to use with the J&W Minix 780G-SP128M board on ebay
http://cgi.ebay.com.au/AMD-Phenom-II...item2304dea19a
Has anyone on here delt with the seller? My concerns are his shipping methods seems average to send it all they way to the land of down under
are any mini drives available with solid state hard drive??
they boost startup speed tenfold and dont heat as much..
sorry rich, much too small
