FYI, the Commell LV-671 is a Pentium M board, not P4.
The LV-673 is a PM board also which I currently use (successor to the LV-671).
oldmadog and acuracl - both have been added - thanks for the input!
Jan Bennett
Jarrod - Holden VX S!
moved the 671 and added the 673 - good eyes!
Jan Bennett
Commel LV677 (or LV677-DC)
CPU: Intel Core Duo and Intel Core Solo processors @ 667MHz FSB.
Memory: 2 x 240 pin DDR2 533/667MHz up to 4.0GB.
Chipset: Intel 945GM and ICH7-M.
VGA Interface: Intel 945GM integrated GMA 950 Technology.
LVDS Interface: 18-bit dual channel LVDS interface.Supports up to WUXGA panel resolution.
TV out: HDTV built-in.
LAN Interface: Intel 82537L PCIE Giga LAN
PCI Enhanced IDE: UltraATA100 IDE up to 2 ATAPI .
Serial ATA: Integrated Serial ATA controller facilitates high-speed data transfers at up to 150 MB/s for each of 2 ports.
Audio: Intel ICH7-M integrated with Realtek ALC880 High Definition Audio.
I/O Ports:
1 x RS232 and
1 x RS232/422/485 Serial Ports
1 x Parallel port
6 x USB2.0 ports
1 x DB15 VGA port
1 x IEEE1394
1 x PS/2 keyboard and mouse ports.
Extended Interface:
One PCI Express x 16 bus add-in card connector
2 x Mini-PCI socket.
SSD: IDE1 supports DOM
1 x CompactFlash socket (underneath board)
GPIO Interface: Onboard programmable 8-bit Digital I/O interface.
Power supply: ATX P/S or DC 8~21V used optional.
Power requirements : Most core duo use a max of 31watts, and the DC board version has built in regulator so you only need a uSDC20A from mpegbox and you will get ypur 12V/5A + 5V/3A onboard regulated for devices such as hd's and usb hubs. The onboard regulator also survives engine cranking and ranges from 8 to 21 Vdc
Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
dopehead - added - thanks!
Jan Bennett
how does the The i945GTt support Duo 2 ? i can't find any Duo 2's with other than LGA775 socket ? the i945GTt only uses 479 right ? Also FSB is 1066 mhz on Duo 2 and the i945 only runs 667, just a bit confused as to how this will work ?
apparently it doesn't...it's not listed as such on the web page. will make the change.
Jan Bennett
oh, good.....otherwise i would have felt screwed just buying the lv677dc board that doesn't support duo 2
this mobo seems interesting from
KONTRON the 986CD-M/mITL
Support Yonah and Merom CPU core
Front Side Bus 533/667 MHz
Intel® 945GM + Intel® ICH7R Chipset
Intel® GMA950 graphic controller on board
Flat Panel Display Support
Dual independent Display Support (incl. 2x LCD)
1x 16x PCI-Express /SDVO external graphic card socket
2GB DDR2 memory support
3x 10/100/1000 Mbps Ethernet
8x USB 2.0, 4x RS232C, 2x IEEE1394
1x ATA100 and 4x SATA150/300 IDE Controller
1x Compact Flash socket
1x mini PCI-Express socket for easy expansion of i.e. wireless LAN
On board RAID 0/1/5/10 support with SATA harddisk
7.1ch HDA / AC-97compliant audio output
Size: 170 x 170 mm (6.7" x 6.7")
Originally Posted by oldmadog
link?
I can't find it on their web page.
Jan Bennett
