Page 5 of 13 FirstFirst 12345678910111213 LastLast
Results 41 to 50 of 126
Thread: Mini-ITX boards
  1. #41
    Apr 2006
    Sydney, Australia
    I can't get any replies from http://www.radisys.com/ has anyone had any luck with getting info and prices for this new board Endura TP945GM?
    I want one!
    New Car PC Build list in progress
  2. #42
    _
    Mar 2004
    Little Elm, Texas
    updated with two new boards that NewEgg is now carrying:
    iGoLogic and an AMD compatable board.
    Jan Bennett
  3. #43
    Aug 2006
    Maybe I'm an idiot, but according to what I could dig up on the intel website, the 945GT chipset (as on the AOpen i945GTt-VFA) is not compatible with the Core 2 Duo (Memrom) Processors.
    The 945GM chipset (as on the Commell LV-677) fully supports the Memrom Processors.
    Additionally, (FWIW) the GT is listed as a Desktop/Performance chipset, and the GM is listed as a Laptop/Embedded product.
    My $0.02
  4. #44
    Registered User
    Quote Originally Posted by nunya_binnez View Post
    My $0.02
    I have used my Aopen i945gtt with a T5600 Merom and its fully compatible, I would not expect the gt chipset to be listed under laptop/embedded since it is a desktop mobo
  5. #45
    Aug 2006
    Quote Originally Posted by Kalt View Post
    I have used my Aopen i945gtt with a T5600 Merom and its fully compatible.
    Duly Noted. I was just going from intel's chipset comparison guides, trying to decide on which board to buy. Thought I'd toss it out there.
    Thanks for the input.
  6. #46
    Oct 2006
    Anyone know if the i945GT and i945GM boards support Pentium M?
    I have a 740, 533 MHz FSB.
  7. #47
    Registered User
    Quote Originally Posted by BeemerZ1 View Post
    Nope but you can get a i915GMt-FSA
  8. #48
    Oct 2006
    OK
    I've been looking a bit at that board...
    I already have a MB896, but the one I got from mp3car is missing FireWire and the Marvell Gigabit LAN!
    Because I need the FireWire for an external soundcard I can't use this board
    Tried e-mailing the store, but still haven't got any reply after 6 weeks.
  9. #49
    Variable Bitrate jschrauwen's Avatar
    Jul 2006
    Frankford, Ontario, Canada
    Commell LV-675D
    LV-675D Specifications
    Processor Supports Pentium M/Celeron M socket 479
    400/533 MHz FSB up to 2.26 GHz
    Chipset Intel 845G north bridge
    ICH4 south bridge
    System Memory 1 DDR333/266 SDRAM sockets
    Up to 1 GB memory size
    VGA built-in Intel Extreme Graphics
    On-board DVI connector
    Expansion Slots 1 PCI
    2 Mini-PCI
    Onboard IDE 1 Enhanced IDE (40 pin)
    1 Ultra ATA 100 (44 pin)
    Onboard USB 4 USB 2.0
    Onboard LAN Intel 82541PI Gb
    Onboard Audio Realtek ALC665 AC'97 Codec
    Onboard TV Out S-video & Composite TV-out
    Onboard 1394 IEEE 1394 Firewire
    Back Panel I/O 1 VGA port
    1 LAN port
    2 USB 2.0
    1 Parallel port
    3 Audio jacks: line-out, line-in and mic-in
    1 SPDIF Optical audio
    1 PS2 mouse port
    1 PS2 keyboard port
    1 IEEE 1394 Firewire
    1 TV-out port
    1 S-Video port
    Onboard I/O Connectors 2 IDE connectors (40 pin & 44 pin)
    2 Serial connectors
    1 Slim FDD connector
    1 USB 2.0 connector for 2 USB ports
    1 GPIO connector
    1 SPDIF connector
    1 CD audio input
    1 IRDA connector
    Wake-on-LAN connector
    1 Front panel audio connector
    1 CD Audio-in connector
    2 Fan connectors
    BTX power connector
    BIOS Award BIOS 2/4Mbit flash memory
    System Monitoring & Management CPU voltage monitoring, Wake-on-LAN, Keyboard Power-on, Timer Power-on, System power management, AC power failure recovery
    Operating Temperature 0 ~ 60°C
    Form Factor Mini-ITX (17cm x 17cm)
    Includes ATA 133 flat cable (40 pin, 80 conductor, 3 connectors)
    ATA 133 flat cable (44 pin, 44 conductor, 2 connectors)
    Back plate
    Installation CD
    User Manual
    Heat sink with fan
    DVI connector (with cable)
    Dual serial ports connector
    Slim type floppy cable
    http://gickr.com/results4/anim_5055e...a2b3b197c9.gif
    1990 RHD JDM 300ZX TT 2+2 5sp T-Top
    491RWHP / 18psi / 94 octane
  10. #50
    _
    Mar 2004
    Little Elm, Texas
    added!
    thanks!
    Jan Bennett
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 09:12 PM
  2. MINI atx or Itx
    By JDTUNER in forum General Hardware Discussion
    Last Post: 06-01-2005, 11:31 PM
  3. What is the most popular mini itx board
    By buzzby in forum General Hardware Discussion
    Last Post: 05-14-2005, 05:59 AM
  4. FS: Mini ITX Computer and 7" Touch screen LCD
    By breaker021 in forum Classified Archive
    Last Post: 04-28-2005, 09:22 AM
  5. Mini ITX in car stereo?
    By ljstevens in forum Newbie
    Last Post: 11-26-2004, 11:56 AM
