Page 9 of 13 FirstFirst 12345678910111213 LastLast
Results 81 to 90 of 127
Like Tree1Likes
Thread: Mini-ITX boards
  1. #81
    Oct 2006
    Las Vegas
    Is the Itox G5C100-N-G Core Duo/Solo Mini ITX Motherboard, shown here the same as another listed elsewhere, and I missed it?
    It's been a while...
  2. #82
    _
    Mar 2004
    Little Elm, Texas
    ok guys - because I'm getting extremely busy, and because this list is growing out of control for one person to maintain, I've started a WIKI page for it: http://www.mp3car.com/wiki/index.php/Mini-itx
    Yes, it still needs to be formatted. If someone wants to take it on, GO FOR IT! Remember, the wiki here is built by the users...so don't be shy.
    Everything you can put in there will help someone.
    So please! Have at it!
    Jan Bennett
  3. #83
    Dec 2006
    is s3 standby not a major factor to anyone else but me? Not all motherboards have this feature and I have been looking through the motherboards on these forums ones I am quite interested in but not sure to buy being so I cant find if the board has s3 standby.
  4. #84
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Vasastaden, Stockholms Län, Sweden, Sweden
    I believe everyone (?) is using hibernation and not standby.
  5. #85
    Dec 2006
    oh i see, startup times on standby are almost instant this is what I like about it.
  6. #86
    Elsewhere
    Quote Originally Posted by Alfredbra View Post
    However Standby mode also continues to draw power. Hibernation does not.
    It's a trade-off.
    How about the Wiki?
  7. #87
    _
    Mar 2004
    Little Elm, Texas
    If that's something you would like to see I suggest you do the research and post it up. I will add the information to the information about the boards.
    Jan Bennett
  8. #88
    Dec 2006
    Quote Originally Posted by RedGTiVR6 View Post
    Alot of motherboards you read up on the manufacturers websites dont state the standby options which make it hard to find out unless tried.
  9. #89
    Sep 2005
    Wrong thread but...
    I use hibernate when I leave car. Powersupply configured to stay on for 30s or so before comencing hibernation. If "off" is pressed when motor is running I simply turn off screen, and the system seems to have 0s restart.
    This is handled by a $69 8051 system ->
    http://web.comhem.se/bengt-olof.swing/boot.htm
  10. #90
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    These should get added to the wiki but not sure where they are available.
    http://www.aispro.com/BoxPC/EmbeddedQuery.asp?Type=0508
    AIS-I8512 Mini-ITX Industrial MainBoards
    Form Factor :Mini-ITXProcessor :Intel Penfium M/Celeron M, up to 2 GHzSystem Chipset :Intel 855GME / ICH4 ChipsetSystem Memory :1 x DIMM, Max 1GB DDR 333Power Input C IN (Lockable,Power Jack)
    AIS-I8511 Mini-ITX Industrial MainBoards
    Form Factor :Mini-ITXProcessor :Intel Core Duo/Core 2 Duo/Core Solo/Celeron M ULV Processors, up to 2.33GHzSystem Chipset :Intel 945GME / ICH7M ChipsetSystem Memory :2 x DIMM, Max 4GB DDR2 667/533Power Input C-IN Power input
    AIS-I8514 Mini-ITX Industrial MainBoards
    Form Factor :Mini-ITXProcessor :IntelPentium M/Celeron M processors, up to 2GHzSystem Chipset :Intel 915GME / ICH6M ChipsetSystem Memory :2 x DIMM, Max 2GB DDR2 533/400Power Input C-IN Power input
    AIS-I8513 Mini-ITX Industrial MainBoards
    Form Factor :Mini-ITXProcessor :Intel Penfium M/Celeron M, up to 2 GHzSystem Chipset :Intel 855GME / ICH4 ChipsetSystem Memory :1 x DIMM, Max 1GB DDR 400Power Input C IN (Lockable,Power Jack)
    AIS-A8514 Mini-ITX Industrial MainBoards
    Form Factor :Mini-ITXProcessor :AMD Athlon 64 X2 / Athlon 64 35W/65W CPU, up to 2.6 GHzSystem Chipset :AMD M690G / SB600 chipsetSystem Memory :2 x DIMM, Max 4GB DDR2 800/667/533Power Input :ATX Power input
    AIS-A8511 Mini-ITX Industrial MainBoards
    AIS-A8512-XPC Mini-ITX Industrial MainBoards
    Form Factor :Mini-ITXProcessor :AMD Geode NX1250/1500/1750 processors, up to 1.4 GHzSystem Chipset :VIA KN400/8237R Plus ChipsetSystem Memory :1 x SODIMM, Max 1GB DDR 400Power Input :ATX Power Input
    AIS-A8513 Mini-ITX Industrial MainBoards
    Form Factor :Mini-ITXProcessor :AMD Geode NX1250/1500/1750 processors, up to 1.4 GHzSystem Chipset :SiS 741 CX / SiS 964 ChipsetSystem Memory :1 x SODIMM, Max 1GB DDR 400Power Input C IN (Power Jack)
    AIS-V8521 Mini-ITX Industrial MainBoards
    Form Factor :Mini-ITXProcessor :VIA Eden™ 1.0GHz by EBGA TypeSystem Chipset :VIA CX700 Single chipsetSystem Memory :Two DDR slots 240 pin Support up to 2GB DDR2 400 / 533 SDRAMPower Input :+12 Volts DC-Input(Optional +24V DC-Input)
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 09:12 PM
  2. MINI atx or Itx
    By JDTUNER in forum General Hardware Discussion
    Last Post: 06-01-2005, 11:31 PM
  3. What is the most popular mini itx board
    By buzzby in forum General Hardware Discussion
    Last Post: 05-14-2005, 05:59 AM
  4. FS: Mini ITX Computer and 7" Touch screen LCD
    By breaker021 in forum Classified Archive
    Last Post: 04-28-2005, 09:22 AM
  5. Mini ITX in car stereo?
    By ljstevens in forum Newbie
    Last Post: 11-26-2004, 11:56 AM
