VIA boards
VIA EPIA CN13000
1.3GHz/1.0GHz VIA C7 nanoBGA2 Processor; CN700 North Bridge; VT8237R-Series South Bridge
1 DDR2 400/533 DIMM socket, Up to 1GB memory size
Integrated VIA UniChrome™ Pro AGP graphics with MPEG-2 decoding acceleration
1 PCI
UltraDMA 133/100/66 Connectors
VIA VT1618 8-channel AC'97 Codec
Back Panel I/O: 1 PS2 mouse; 1 PS2 keyboard; 1 Serial; 1 VGA; 1 RJ45; 4 USB 2.0; 1 RCA (S/PDIF or TV out); 1 S-Video; 3 Audio jacks: line-out, line-in and mic-in (Horizontal, Smart 5.1 Support)
Onboard I/O Connectors - 1 USB connector for 4 additional USB 2.0; 2 SATA; 1 Front-panel audio (Mic and Line Out); 1 CIR (Switchable for KB/MS); 1 LPT; 1 CD-in; 2 Fan: CPU/Sys FAN
VIA EPIA EN15000
1.5GHz/1.2GHz VIA C7 nanoBGA2 Processor; CN700 North Bridge; VT8237R-Series South Bridge
1 PCI
2 UltraDMA 133/100/66 Connectors
VIA VT1618 8 channel AC'97 Codec
VIA VT6307S IEEE 1394 Firewire
Back Panel I/O - 1 PS2 mouse; 1 PS2 keyboard; 1 Serial; 1 VGA; 1 RJ45; 4 USB 2.0; 1 RCA (S/PDIF or TV out); 1 S-Video; 3 Audio jacks: line-out, line-in and mic-in (Horizontal, Smart 5.1 Support)
Onboard I/O Connectors - 1 USB connector for 2 additional USB 2.0; 1 1394 connector for 1 1394; 2 SATA; 1 LPC; 1 Front-panel audio (Mic and Line Out); 1 Serial port connector for a second com; 1 CIR (Switchable for KB/MS); 1 SIR pin header (IrDA 1.0); 2 Fan: CPU/Sys FAN; 1 SMBUS; 1 S/PDIF in; 1 S/PDIF out; 1 LVDS/TTL/DVI module (an add-on card is required); 1 Component (YPbPr) video pin header
VIA EPIA SP13000 and SP8000
VIA C3™/ VIA Eden™ EBGA processor; CN400 North Bridge; VT8237R-Series South Bridge
1 DDR266/333/400 DIMM socket. Up to 1GB memory size
Integrated VIA UniChrome™ Pro AGP graphics with MPEG-2 decoder /MPEG-4 Accelerator
1 PCI
2 X UltraDMA 133/100 Connector; 2 SATA Connectors
VIA VT1617A 6channel AC'97 codec
Back Panel I/O - 1 PS2 mouse; 1 PS2 keyboard; 1 RJ-45 LAN; 1 Serial; 2 USB 2.0; 1 VGA; 1 PCA (SPDIF or TV out); 1 S-video; 3 Audio jacks: line-out, line-in and mic-in (Smart 5.1 Support)
Onboard I/O Connectors - 3 USB connector for 6 additional USB 2.0; 1 1394 connector for 1 1394; 1 Serial port connector for a second com; 1 VIP; 1 Front-panel audio (Mic-in and Line-out); 1 CD audio-in; 1 FIR; 1 CIR (Switchable for KB/MS); 1 LPT port ; 1 Wake-on-LAN; 2 Fan: CPU/Sys FAN; 1 I2C; 1 LVDS/TTL module (Optional); 1 +12V power
VIA EPIA ML6000 and ML8000
VIA C3™/ VIA Eden™ EBGA processor; CLE266 North Bridge; VT8235M South Bridge
1 DDR266 DIMM socket, Up to 1GB memory size
Integrated VIA UniChrome AGP Graphics with MPEG-2 Accelerator
1 PCI
2 X UltraDMA 133/100/66 Connectors
VIA VT1616 6 channel AC' 97 codec
Back Panel I/O - 1 PS2 mouse; 1 PS2 keyboard; 1 Parallel; 1 RJ-45 LAN; 1 Serial; 2 USB 2.0; 1 VGA; 3 Audio jacks: line-out, line-in and mic-in (Smart 5.1 Support)
VIA EPIA MII12000 and MII10000 and MII6000
Integrated VIA Unichrome AGP graphics w/MPEG-2 Accelerator
1 PCI
2 X UltraDMA 133/100/66 Connector; 1 x FDD Connector
VIA VT6103 10/100 Base-T Ethernet PHY
VIA VT6307S IEEE 1394 (Optional)
Onboard CardBus / CompactFlash - CardBus Type I & Type II; Ricoh R5C476 II / R5C485 CardBus Corntroller
Back Panel I/O - 1 CardBus Type I and Type II slot +1 CompactFlash; 1 CompactFlash; 1RJ-45 LAN; 1 PS2 mouse; 1 PS2 keyboard; 1 Serial; 2 USB 2.0; 1 VGA; 1 RCA (SPDIF or TV-Out); 1 S-Video; 1 1394; 3 Audio jacks: line-out, line-in and mic-in (Smart 5.1 Support)
Onboard I/O Connectors - 1 USB connector for 2 additional USB 2.0; 1 Front-panel audio (mic-in and line-out); 1 CD Audio-in; 1 FIR; 1 CIR (Switchable for KB/MS); 1 Wake-on-LAN; 1 LPT port; CPU/Sys FAN/Fan 3; 1 Connector for LVDS module (Optional); 1 Serial port connector for second COM port
VIA EPIA M10000 and ME6000
Integrated VIA Unichrome AGP graphics with MPEG-2 Accelerator
1 PCI
VIA VT1616 6 channel AC'97 Codec
Back Panel I/O - 1 PS2 mouse; 1 PS2 keyboard; 1 Parallel; 1 RJ-45 LAN; 1 Serial; 2 USB 2.0; 1 VGA; 1 RCA (SPDIF or TV out); 1 S-Video; 3 Audio jacks: line-out, line-in and mic-in; can be switched to 6 channel output
Onboard I/O Connectors - 1 USB connector for 2 additional USB 2.0; 2 1394 connectors for 2 1394; 1 Front-panel audio connector (Mic and Line Out); 1 CD Audio-in; 1 FIR; 1 CIR (Switchable for KB/MS); 1 Wake-on-LAN; CPU/Sys FAN/Fan 3; 1 SMBUS; 1 Connector for LVDS module; 1 Serial port connector for a second com port
VIA EPIA 800 and 5000
VIA C3/EDEN EBGA Processor; PLE133 North Bridge; VT8231 South Bridge
2 PC133 DIMM sock, Up to 1 GB memory size
Integrated AGP 4X Graphics
1 PCI
VIA VT1612A 2 channel AC'97 Codec
Back Panel I/O - 1 PS2 mouse, 1 PS2 keyboard, 1 VGA, 1 Parallel, 1 RJ-45 LAN, 1 RCA (SPDIF or TV out), 1 S-Video, 2 USB 1.1, 1 Serial, 3 Audio jacks: line-out, line-in and mic-in
Onboard I/O Connectors - 1 USB connector for 2 USB 1.1, 1 CD Audio-in, 1 FIR, 1 CIR, 1 PS2, 1 CPU/Sys FAN
Jetway 627F Series
PDF Link
Support VIA C3 processor in EBGA packaging, for 133MHz Front Side Bus Frequency; VT8623 North Bridge; VT8235 High Bandwidth Vlink Client South Bridge
1 x 184-pin DDR Module Sockets Support Max 1GB, 2.5V DDR266 DDR SDRAM
Support 2 x Ultra DMA 133 IDE Interface
128bit 2D/3D graphics engine
Support NTSC/PAL TV system S-Video/AV Output
6xUSB 2.0, 1xParallel
Jetway / Phylon / Versa / Vista J7F2WE
PDF Link
VIA CN700 Northbridge + VT8237RP Southbridge Chipsets (MCP51G); VIA C7 Nano-BGA processor
CPU core speed
1G0 is 1.0GHz C7 CPU [All]
1G2 is 1.2GHz C7 CPU [Jetway Only]
1G3 is 1.3GHz C7 CPU [Phylon Only]
1G5 is 1.5GHz C7 CPU [All]
Front Side Bus 133MHz
Single Channel DDR2 400 Memory DIMM
2 Serial ATA Devices with RAID 0, 1
2xAD Connector With Expansion Daughter-boards
AC’97 6 Channel Audio CODEC
VIA VT6307S IEEE1394a Controller for J7F2E / J7F2WE
Jetway J7F4 Series
PDF Link
VIA VT1622A TV encoder
VIA EPIA VB6002
VIA VN800 North Bridge; VT8237R series South Bridge
1 DDR2 533 DIMM socket; Up to 1GB memory size
Integrated VIA UniChromeTM Pro AGP graphics with MPEG-2 decoding acceleration
1 PCI
VIA VT1618 AC'97 Codec with 6-channel support
Onboard I/O Connectors: 2 USB pin connectors for 4 additional USB 2.0; 2 SATA; 1 LPC; 1 LPT; 1 Digital I/O (4GPI/4GPO); 1 Front-panel audio (Mic In and Line Out); 1 COM (with Vcc 5V/12V Support); 1 CIR (Switchable for KB/MS); 1 SIR; 1 S/PDIF out; 2 Fan (CPU/Sys FAN); 1 SMBUS; 1 LVDS/ DVI module (an add-on card is required); ATX Power
Back Panel I/O: 1 PS2 mouse; 1 PS2 keyboard; 1 Serial; 1 VGA; 2 RJ-45 LAN; 4 USB 2.0; 3 Audio jacks: line-out, line-in and mic-in (Horizontal, Smart 5.1 Support)
